Results 1 to 4 of 4
Thread: Into S3 Suspend, boots cold :(
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I recently updated to a jetway jnc62k MB and a SSD. The SSD takes a little longer to resume than my ol' sata. I have alwasy wanted to use S3, and now I have a capable board. Problem is, when I shut down (using M2-ATX) it goes into standby as it should. If I start up within a minute or two it comes out just as it should. When I come out after more than 10 minutes it does a cold boot. My battery is fine and I have no problems with power during or after this. I have changed the Registry for the USB as i googled a solution and found this was recommended. S3 is enabled in the bios as well, windows power options set to "Standby"..
    What can I do>?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Check your M2 jumper settings and refer to the manual. Hardoff should be set to never.
    Mar 2006
    Colorado, but Canadian!
    the m2 cuts power and hence the ram loses its saved state after a set period.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    PA
    Quote Originally Posted by 2k1Toaster View Post
    Ya know I can't believe I overlooked this..I guarantee that is what it is.... I'll give it a try in the morning and report back, THANKS!
  1. m2atx suspend problem
    By dyne in forum Power Supplies
    Last Post: 12-02-2008, 08:37 PM
  2. Nano-ITX board with S3 suspend
    By _Dejan_ in forum General Hardware Discussion
    Last Post: 12-04-2007, 02:17 AM
  3. Replies: 7
    Last Post: 11-14-2005, 03:58 PM
  4. S3 / Suspend To Ram etc... help?
    By Jaz in forum General Hardware Discussion
    Last Post: 08-26-2005, 11:28 AM
  5. S3 Suspend to Ram Setup
    By gospeed.racer in forum General MP3Car Discussion
    Last Post: 05-03-2004, 06:17 PM
