Results 1 to 3 of 3
Thread: USB Startup Issues
    Dec 2006
    Manchester, England
    USB Startup Issues
    Hi all,
    I have a bit of an issue with my setup on startup - the laptop i'm using only has one USB port so i have a run from the laptop in the boot to behind the dash where there is a 4-port USB passive hub.
    Attached to this is a USB matrix orbital display, a griffin powermate and a Car2PC Pioneer HU adaptor.
    Now for some reason the hub is not detected/initialised properly when the laptop boots/resumes/un-hibernates and unless i unplug the devices before plugging in the hub it doesn't work.
    Any suggestions on solutions would be appreciated! I have no problem building something with electronics or writing software as a solution either.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by davelew99 View Post
    Hi all,
    You could try using X-Port, which helps GPS to come out of hibernation. It also has a option so that when you come out of hibernation it can reset devices to activate it correctly so your PC will recognize it. Infact X-Port will do that for most USB devices. Just check mark the hub in the device list and thats it.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Dec 2006
    Manchester, England
    Thanks - from reading the XPort page its based on an MS tool called DevCon - i may just use that in conjunction with ShutControl which im using already.
    I'm not sure if it will work - if its the hub not starting up properly because of the devices connected i'm going to have to think of somthing else.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  3. XP startup issues - intermittent!
    By badass101 in forum General Hardware Discussion
    Last Post: 10-25-2005, 05:30 AM
  4. usb flash drive issues??
    By djmickyg in forum Hardware Development
    Last Post: 08-27-2005, 10:27 PM
