Results 1 to 10 of 13
Thread: Freezed carputer
    Low Bitrate BADMOPAR's Avatar
    Mar 2007
    Czech Republic
    Freezed carputer
    Hi,
    when i leave my car outside over the night and outside temperature goes below - 10C,my carputer will not work.The CPU fan runs,but no sound and no picture is visible.Has anybody same problem?
    I don't wanna be a product of my environment.
    I want my environment to be product of me.
    Jan 2008
    try removing ram and replacing it, had a simliar problem but was that i knocked the ram
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by BADMOPAR View Post
    Hi,
    sounds like your HD doesnt operate in the cold.
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2007
    Dawson, IL
    Having some cold weather issues with mine but I suspect it is the motherboard since the boards two LEDs are not lighting as they normally do on startup - will boot once it warms up a little though and only happens when it gets about five degrees or more below 0 C. Sometimes the CPU fan and system fan will run when it does not boot and other times they will not run.
    Cheap board though - researching others, suggestions would be welcome
    If anyone gives me a rev - I give them the Bird
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    ^I would recommend a motherboard with solid state capacitors. I think most (if not all) of the newer Jetway's are solid state. My J7F2WE2G has been rock solid so far.
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    This morning it was -20C in Toronto, psu in trunk would not let carputer boot up, warmed car up for 15min, all is well...
    Check sig for pc specs...
    Dec 2006
    Manchester, England
    Perhaps you could fit some sort of heater?
    This is common practice in external marine systems such as Radar where the magnetron coil must be heated before having power applied (otherwise it significantly reduces the lifetime of the magnetron)
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    This may be a stupid question, but I am finding that when my computer resumes after hibernate, when it's around 0C, my serial ports aren't starting up. (Everything else comes up fine). This causes an issue if the last thing I did was listen to HD Radio. The computer basically stalls. Windows boots, StreetDeck comes up, but the radio (serial port) doesn't resume and the process can't be killed (through task manager). I have to do a hard reboot, listen to something else, wait a few minutes for the computer to warm up, then reboot again in order for the serial port to power on.
    Is there a way to force a serial port on through windows or does it have to start up during post? Just wondering if there is a way to have the computer warm up for a few, then force the port open rather than reboot.
    My opinion is my own.
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by danielkh View Post
    It has to start up during post, just like legacy ps2 devices do.
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by dMand View Post
    That's what I thought. Thanks for the confirmation. Think I might try the serial to USB converter solution and see if that might do for winter startups.
    If that's the only issue I have all year, I consider myself lucky.
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  2. Carputer confusion- n00b needing help
    By TonyMartin in forum Newbie
    Last Post: 03-10-2006, 01:11 PM
  3. Carputer confusion- n00b needing help
    By TonyMartin in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:43 PM
  4. wikipedia: carputer definition
    By pRoFiT in forum Off Topic
    Last Post: 12-31-2005, 09:32 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
