Results 1 to 4 of 4
Thread: Well, my AMD 64 X2 4000+ finally arrived!
    FLAC WuNgUn's Avatar
    Sep 2007
    ...and what a difference!
    I know others were running dual cores here, so I knew my OPUS would be up to the task.
    I didn't hold out for the (much) more expensive 2MB L2 cache version, because the benefits aren't really worth it on such a narrow-focus PC.
    BTW, I had a 1.8Mhz single core before...which held it's own fine, but it's just SO much snappier now using the PC, especially with the DSP running in the background...
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by WuNgUn View Post
    Yes, it's a big difference going from single to dual core. Now put Windows7 on that puppy.
    Congrats!
    JWM
    JWM is offline
    Aug 2008
    Yep, I'd recommend a dual core of any speed... they are as you said, just SO much snappier... even just a 3600 dual core.
    While a car-pc doesn't need anything special, a dual core on its own (nothing fancy, look at mine :P) will make a car-pc a lot easier to use. Lots more processing power means less waiting and less likely to have songs stall.
    My old AMD 2800+ (single core) was a bit too slow for a car-pc, ran centrafuse fine until something in the background happend then everything will slow down... and also when searching through music was a bit slow... and sometimes (rarely) stall'ed while playing songs!!
    Congrats!!
    Sep 2007
    Thanks...
    I did some testing, and I can (barely) run my audio stream at 24-bit, 192Khz sampling with the dual with AudioMulch doing all the DSP...
    However, the best material I have us 24-bit, 96Khz (DVD-A, SACD), and it handles it like a champ at that setting. Maybe not a totally audible difference (by ear), but like they say, your chain is only as good as it's weakest link!
  1. IEI KINO-690S1 AMD Turion 64 Mini-ITX Mainboard
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-17-2009, 06:20 PM
  2. Power Supply for AMD Turion 64 x2 TL-60
    By tavenger5 in forum Power Supplies
    Last Post: 11-20-2007, 01:18 PM
  3. FS: AMD Turion™ 64 X2 Dual-Core Mobile 31W TMDTL50HAX4CT
    By lxt_123 in forum Classified Archive
    Last Post: 03-06-2007, 04:36 PM
  4. FS: AMD Athlon 64 3000+ and 3700+ CPU's
    By james33440 in forum Classified Archive
    Last Post: 09-14-2006, 08:55 PM
  5. Athalon Turion 64 X2 board?
    By oldmadog in forum General Hardware Discussion
    Last Post: 08-26-2006, 12:52 PM
