+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Looking for Buttons (maybe with USB?)
    May 2008
    I'm trying to find some buttons i can use with my CarPuter mainly as a Next/Previous for Winamp but i can't find anything that's either US or Com Port with 2 buttons. I've looked at Phidgets also but they don't have any buttons either just a knob that can be a button but hat's not what i want. (besides i want 2 side by side)
    does anyone have any ideas of something out there available that could fit this demand?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    you could just get 2 standard buttons or a panel that has 2 buttons in it and connect that to a Fusion Brain and have the software send whatever key it is that you need to get winamp to next/prev. could be a little involved, but really its not that difficult.
    May 2008
    ok, I see what you mean by fusion brain but where would i get buttons that connect to that?
    Oct 2007
    Haledon, NJ
    any standard automotive momentary button from you local auto parts store or radio shack. the software that comes with the unit is fully programmable and customizable so you would hook the switch up to one of the analogue inputs and tell the program that when the input sees voltage to execute the next / prev command
    May 2008
    so I can use buttons that are already in my car? just hook up the power/ground to the board?
    Constant Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    If you have a spare PS2 keyboard laying around and your computer has the free port to use it or have a USB keyboard around.
    Simple remove the cable and main interface card from the case of the keyboard and follow the two wire/circuit lines that run from the keys "Z" and "B" and wire two switches to them both.
    Then all you need todo is find a switch that fits the looks and style you like. From radioshack/jaycar/dse/online.
    This method works perfect and simply is the same as pressing a key on the keyboard
    have a look at: Keyboard Hack
    2004 Holden WL Caprice Auto GENIII
    Base PC = Installed
    Front End = In Progress 75%
    OBD2 Interface = Installed / V2 Due Soon
    Realworld Interfaces = In Progress 20%
    Internet Linking = In Progress 10%
    Voice Control = In Progress 35%
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by Ludercrs View Post
    the brain will have 3 pins in the header you connect to. one is 5v+ one is ground and one is 5v input - you would just run a wire from the 5v+ to the button of your choice then out the other side of the switch to the 5v input of the brain
    To understand how it works in more detail checkout their website and their section of the forum
    May 2008
    ya i understand how the brain works i just don't know what would connect to it. I was expecting stuff made to connect to it and not stuff i have to McGuyver.
    Fusion Brain Creator
    Mar 2005
    You don't have to macguyver. Any switch will work. We didn't make switches, because everyone has different taste. Just pick up a switch, and one of our three pin cables.
    Mar 2008
    Adelaide, Australia
    Im sorry to ask, But why would you go with the fusion option as this will would require alot of work.
    Using something like the keyboard hack is fool proof and fault proof along with u can simple use the default keystrokes for winamp and build a whole control panel and still have your fusion system available for more complex setups?
    Base PC = Installed
+ Reply to Thread
  1. Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 08-26-2011, 09:30 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    Last Post: 10-03-2010, 11:30 PM
  3. Newbie build-up: Ampie CarPC
    By EEEEeeee36 in forum Newbie
    Last Post: 03-28-2008, 10:03 PM
  4. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  5. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
