Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: What do you guys think of this motherboard for my build?
    Jan 2009
    GIGABYTE GA-MA69VM-S2 Socket AM2 AMD 690V Micro ATX Motherboard
    Specification
    Model
    Socket
    Socket AM2+ Motherboard
    CPU
    AMD Socket AM2 Athlon™ 64 FX / Athlon™ 64 X2 Dual-Core / Athlon™ 64 / Sempron™ processor
    Chipset
    North Bridge Chipset: AMD 690V
    South Bridge Chipset: AMD SB600
    Supports
    Windows Vista
    Memory
    4 DDR2 DIMM memory slots (supports up to 16GB memory)(Note 1)
    Supports dual channel DDR2 800/667/533/400 DIMMs
    Supports 1.8V DDR2 DIMMs
    Expansion Slots
    1 PCI Express x 16 slot
    1 PCI Express x 4 slot
    2 PCI slot
    Onboard Video
    ATI Radeon Xpress 1200
    LAN
    Realtek RTL8110 Gigabit Ethernet
    Audio
    Realtek ALC888 Audio Codec
    BIOS
    1 4Mbit flash ROM
    Use of licensed AWARD BIOS
    PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
    Other Features
    Supports @BIOS
    Supports Download Center
    Supports Q-Flash
    Supports EasyTune (only supports Hardware Monitor function)(Note 3)
    Supports Xpress Install
    Supports Xpress Recovery2
    Supports Xpress BIOS Rescue
    H/W Monitoring
    System voltage detection
    CPU / System temperature detection
    CPU / System fan speed detection
    CPU / System warning temperature
    CPU fan failure warning
    Supports CPU Smart Fan function(Note 2)
    Rear Panel I/O
    1 PS/2 keyboard port
    1 PS/2 mouse port
    1 parallel port
    1 COMA port
    1 VGA port
    4 USB 2.0/1.1 ports
    1 RJ-45 LAN port
    6 audio jacks (Line In / Line Out / MIC In/Surround Speaker Out (Rear Speaker Out)/Center/Subwoofer Speaker Out/Side Speaker Out)
    Internal I/O Connectors
    1 24-pin ATX power connector
    1 4-pin ATX 12V power connector
    1 floppy connector
    1 IDE connector
    4 SATA 3Gb/s connector
    1 CPU fan connector
    1 system fan connector
    1 front panel connector
    1 front audio connector
    1 CD In connector
    1 SPDIF In/Out connector
    3 USB 2.0/1.1 connector for additional 6 USB 2.0/1.1 ports by cables
    1 COMB connector
    1 Power LED connector
    1 Chassis Intrusion connector
    1 TV out connector
    Form Factor
    Micro ATX Motherboard Form FactorDimension: 24.4cm x 24.4cm
    Hooked up to a:
    EVGA 7900 GTX 512MB Video Card
    Soundblaster XFI sound card
    AMD 3.2GHZ dual core black edition processor
    4 gigs of Patriot ddr2 ram?
    Dec 2007
    you know that that will need over 300w probably, with that video card, now if it was a 7800 then maybe not so much but the 7900 needs external power
    you did not specify anything else for your build, so nobody can really give you any other advice, until you do
    Jan 2009
    Well I am looking for a power supply also. I don't know which ones are best suited for car applications. What would ya'll suggest?
    Dec 2007
    i would suggest dc to dc, but the more watts the more expensive they go, and if you look on this site you can find all the info you need
    just expect to pay a lot of a high watt carPC psu
    thats why you should really consider do you really need a 7900? and what other future peripherals will u be using?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    If your going with a monster MoBo like that, then I would get a OPUS 320. Even with that, you are cutting it really close because you also have to add the devices that you are going to connect to the equation. If you want alot of power and like to stay with AMD, then I suggest the Kino-690S1, which is the board I use. I am anti-Intel. The MoBo is expensive, but the processor is cheap. I got my Turion x2 64 TL-58 1.9GHZ for $45.00 dollars. Also got 4 GB of Sodimm RAM for $40.00. Here is a link, its a open box item, but you save $100.00 dollars. http://www.logicsupply.com/products/kino_690s1. What is nice is that it has a impressive built in graphics card. I think its a 1250 Radeon Express.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    I'm using a similar board, but from ASUS, check my sig for specs...
    FLAC WuNgUn's Avatar
    Sep 2007
    OPUS 320 and ditch the vid card. Onboard uses WAY less power but will do everything you need it to do...
    2GB RAM will be PLENTY as well, on an optimized OS...but DDR2 is dirt cheap, so your call...
    CPU might be a bit of overkill too...X2 is perfect, but get the 2.6Ghz model...PLENTY of oomph!
    Dec 2007
    i suggest you research the mobo for undervolting and under clocking ability, why? simply because you can take that BE and get it down to mobile specs with lowering the voltage and maybe underclock it a bit, lets face it you wont need all that 2ghz+ for a carpc, and you can always make more then one profile if you ever consider to game or something like that
    im not 100% you should go with external video, I would go with a mobo that has integrated video as well, you cant go wrong with ati or nvidia, plus you might be able to do some form of sli or whatever with the integrated video and the external video card
    but to be honest unless your going with something bigger then 7” screen I would not invest in an external video card even if you have one, simply because you will not run games on high rest on a 7” screen, you will do just fine with integrated ati/nvidia with 800x600 with medium settings on most games, slap in another low power video card with sli or whatever and you can double your frame rate with a fraction of power
    i would suggest a amd/ati 3200
    http://www.newegg.com/Product/Produc...lue=757%3A7619
    Jan 2009
    Yeah the video card and other stuff Is stuff I had just laying around.... I can do without the video card, but I do like the processor.
    Sep 2007
    I'd personally stay away from nVidia chipset/integrated video solutions...
    ATI is far better.
  1. M2-ATX with Intel Atom Motherboard Issues
    By jeremy480 in forum M2-ATX
    Last Post: 12-05-2010, 01:28 AM
  2. MTB-057 Intel D945GCLF Mini-ITX Motherboard OS Installation problems
    By Fiberoptic in forum MP3Car Products - store.mp3car.com
    Last Post: 07-08-2008, 02:50 PM
  3. Start problem with new jetway 7F2WE motherboard
    By superkenel in forum General Hardware Discussion
    Last Post: 08-03-2007, 07:06 AM
  4. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  5. My first design and build - need advice from you guys.
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-02-2002, 01:04 AM
