forgot to add the diagram
ok so check it out i'm building this quad from scratch for resale its a nice frame with a 600 cbr engine taken from a bike and i have this idea.
the idea is that i want to have a proximity start kinda like the new altimas have except a little different.
what i plan to do is have a start button on the quad and when i want to start the quad i simply hold the button until the engine is started. except i want the power to the starter to be controled by a relay i'm pretty sure a SPDT thats controled by a RFID alarm that has proximity lock/unlock. the problem i have is that i'm not sure if the lock/unlock pulse from the alarm module will be enough to trigger the relay to change position and stay there.
let me try to draw out a rough diagram
the alarm module i have found is this:
http://cgi.ebay.com/NEW-K9-SOMBRA-AU...3%3A1|294%3A50
i hope that if the SPDT relay i have in mind doesn't work maybe theres a pulse operated relay that only changes position when energized.
tell me what you guys think.
2008 Civic... Sound system... then carputer install...
WORK IN PROGRESS
If you look at my avatar closely, you can see a chick with two big knockers....
WORK IN PROGRESS
