Results 1 to 10 of 13
Thread: Which DVDROM? Does it matter?
    May 2008
    I've been looking all day for what DVDrom I should be looking to get for my CarPC but have only found what drives others are using. Is there any specific manufs/models I should be looking at? I'm concerned about the disc skipping over bumps. I don't require a slim drive since I have the space for a regular drive... I'd prefer a slot-load for a sleeker install.
    Oct 2008
    Don't really matter. You can get a Pioneer, Samsung or LG brand for about $30-40.
    May 2008
    Aside from brand loyalty, do some perform better than others in the Car environment as far as skipping discs are concerned?
    Oct 2008
    Haven't seen a 5.25" drive that has an Antiskip feature as these are supposed to be installed in a stationary case. If you have a current PC that has a DVDdrive, try running a DVD or CD on it, lift the case and shake it up and down. See if it skips. heh.
    May 2008
    Probably a dumb quesiton but would a laptop drive skip less than a desktop drive?
    Oct 2008
    that's what i'm using now. haven't had issues. that 2mb buffer helps. try finding one that has 8mb
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    A laptop drive along with hard drive is made for the bumpy environment.
    Along with getting a lappy drive, I would suggest getting a lightscribe if you plan on using it to rip/burn cds.
    Can easily generate some software which creates the playlist on the disc itself as the cover.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    Nov 2008
    with laptop drives the cd/dvd typically clicks in also which helps to keep it from bouncing around where desktop drive just sit in place, although the slot load drives hold it better
    Variable Bitrate Deric's Avatar
    Sep 2006
    I would suggest a slot load. The laptop tray style always seems a bit fragile to me.
    May 2008
    ya, im thinking slot load
  1. Wireless links - do BOTH ends matter?
    By agarbino in forum Wireless Communications
    Last Post: 07-26-2007, 06:43 PM
  2. Replies: 2
    Last Post: 11-22-2006, 02:19 AM
  3. Does Bluetooth version matter?
    By warnockm in forum Wireless Communications
    Last Post: 11-16-2005, 10:36 PM
  4. FS: Single DIN case and slotload DVDROM for Via Epia MIIK
    By tf82 in forum Classified Archive
    Last Post: 06-10-2005, 02:16 AM
  5. panasonic slot dvdrom problem
    By illycut in forum Input Devices
    Last Post: 08-28-2004, 11:26 AM
