Yes you can do it, get a "Y" adapter.
The problem would be volume control, you wont have a crossfade.
Code:AMPLIFIER | | /\ <----Y adapter / \ / \ / \ / \ / \ / \ CD Tape deck
I was curious about how one would go about connecting two head units to one amplifier without causing damage.. I have an Eclipse 54400 cd headunit that I would like to keep using, but ive seen cheap tape decks that have AUX-IN for like $30 and this would be a great way to get the quality sound of a direct aux-in connection.
Is this feasable, and if so what would be needed?
-Lee
You'll probably fry both decks' preouts by doing that. Ive seen it happen before. First deck should goto second deck's AUX in. Second deck then go to the amp. If you got decks with no AUX in, then you need to build a RCA switcher. I can build you one for a fee if you're interested. PM meOriginally posted by osirisdon
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
oops
Please don't do thisOriginally posted by osirisdon
I have done this in the past with absolute ZERO problems, that why I said YES you can.
What's that smell?Originally posted by osirisdon
If you come out talking sh1t don't try to turn around and wipe you azz.
y adapters are your enemy they work like antenna towers at zeroing in on noise
Yea I wouldn't do the direct connect either.
You could run the output of one to the input of the other(if it has inputs)
Or you can buy a mixer (small portable) or build a mixer. If neither head units have input, then get the mixer.
Try this:
Code:(0) to AMP | |-------- | | / / \ \ 100 Ohms / / \ \ | | | | CD Tape deck Use 1/4 watt resistors and you'll be ok.
