Results 1 to 10 of 11
Thread: Problem with Intel DG45FC Graphics
    Oct 2003
    Copenhagen, Denmark
    Hey Guys,
    Not so carpc related, but i know some of you have the Mini-ITX board DG45FC from intel. I am having problems with the graphics output, whenever i disconnect or turn off my tv, or reboot the machine, it just comes up with a picture on the tv that looks like a refresh rate problem or something, and the drivers are really crappy, basically no settings other than resolution and refresh rate, but this seems to get reset or something after reboot. Only way i can get my display back is safe mode/remove drivers and boot again and install the drivers once again. but the second i reboot i get the same error....any suggestions ? i am using newest g45 drivers from intel.
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    FLAC WuNgUn's Avatar
    Sep 2007
    What do you mean TV?
    Are you not using a VGA/DVI device? Just a TV-out??
    I would suggest looking in your BIOS setup for which video device to boot from.
    With that said, I've always loathed anything with integrated Intel graphics...just
    ****ty graphics performance all together...
    Oct 2003
    Copenhagen, Denmark
    by TV i mean my Sony W3000 42 inch Full HD LCD TV via HDMI, Intel had promoted this as being able to decode VC1/h264 in 1080P with the X4500HD, which does not work properly due to bad drivers from intel, but i am using it anyway, since i have a 3ghz core 2 duo cpu which will do that job instead. I don't need 3D acceleration, so i don't really care about gaming performance and such, all i care about is HDMI/DVI output and optical spdif sound, which that mini-itx board has.
    Sep 2007
    If it has HDMI and VGA output, in other words dual display, it might be when you unplug the TV, and plug it in, it's getting the dual display mixed up? Try plugging a monitor in as well as your TV and retest...
    Oct 2003
    Copenhagen, Denmark
    It has HDMI and DVI, and no, nothing is on the DVI port either, once the hdmi goes berserk.
    Oct 2003
    Copenhagen, Denmark
    I just found a new driver version for the G43 chipset which also works for G45, and this has solved the problem :-)
    Sep 2007
    Good going...
    Newbie miko55's Avatar
    Jun 2007
    Ljubljana, Slovenia, Europe
    Quote Originally Posted by _dopehead_ View Post
    Please share the link, I am in same s..t as you
    Slovenia, Europe
    best on-line radio
    Oct 2003
    Copenhagen, Denmark
    I can't find the link right now, but its the latest intel driver for the G43 chipset, it works for G45 as well.
    Nov 2009
    Intel DG45FC ITX Motherboard question on Video
    Noticed folks discussing HDMI and DVI ports on the DG45FC motherboard from intel.. does anyone know if the HDMI and DVI can be used simulaniously in a dual montior configuration... I don't have the system so I can't test it outright.. if anyone has tried it.. I'd be interested in learning from your experience. Thanks in advance for your help..
    L8
    The Gray Wizard
    (aka: Matthew Romero)
    Wizard's Network and Internet Services
    Albuquerque, New Mexico USA
  1. Intel DG45FC and 800x480
    By carlb99 in forum General Hardware Discussion
    Last Post: 12-23-2008, 02:18 AM
  2. Toshiba SatPro 6000 or Intel D201GLY2?
    By x10 in forum General Hardware Discussion
    Last Post: 01-25-2008, 12:48 AM
  3. Would a graphics card solve my problem??
    By Macflurry in forum General Hardware Discussion
    Last Post: 02-28-2007, 04:34 PM
  4. Problem with S3 graphics and Xenarc
    By crooper in forum General Hardware Discussion
    Last Post: 02-01-2007, 01:07 PM
  5. Intel 810 Book PC Display Setting Problem
    By OKC-X in forum General Hardware Discussion
    Last Post: 09-18-2002, 07:45 PM
