Results 1 to 10 of 11
Thread: High quality audio drivers.
    Variable Bitrate Uraijit's Avatar
    Aug 2007
    Utah
    Just curious if anybody knows where I can get some drivers that might help with my audio. I've got the MSI RS482M http://global.msi.com.tw/index.php?f...=171&cat3_no=7
    I'm getting some "crosstalk" from the onboard audio. It's picking up trash noise while the system is running other processes. When I move the mouse, I get noise that mirrors the movement, etc.
    I've read that better drivers can help with this. It's got the realtek ALC655 chip. Anybody know if there's anything similar to the kXProject drivers for the RealTek audio hardware?
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Elsewhere
    I think you should look at your cables & how/where they are run first.
    How about the Wiki?
    Mar 2006
    Blog Entries
    1
    On one of my carpc setups I could hear all kinds of strange computer related noises and assumed my built in audio was crappy -- fixed it by using a ground loop isolator.
    Aug 2007
    Utah
    Quote Originally Posted by BlackStealth View Post
    Yeah, seeking out grounding issues is this weekend's project. But I thought I'd start gathering information regarding other possible issues as well.
    Thanks for the ideas.
    Any suggestions on the best ground loop isolator for not too much cash? I've got 4 channels of audio to isolate.
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Mar 2006
    Blog Entries
    1
    I purchased PAC ground loop isolators to fix mine, and they work fine. Not sure which ground loop isolator is the best.
    Aug 2008
    Northern England
    Have you tried grounding your RCA's?
    Such a simple thing sorted all of my round issues.
    Aug 2007
    Utah
    Alright, today was pretty successful. I got my ground loops all sorted out. Everything is properly grounded now.
    Still getting alternator whine, but at least the buzzing and popping is gone.
    I isolated my alternator whine to being caused by my line drivers. If I removed them from the equation, the alternator whine disappears, my audio just doesn't get as loud as I would like.
    I tried every possible grounding work-around, to no avail. These are really cheap $6 line drivers, so I'm not surprised that they're doing this. So I guess now I just need some suggestions on a good quality line driver solution. I don't want to spend over $50 for 4 channels, whatever the solution.
    Any suggestions?
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Aug 2007
    Utah
    Nevermind. I found a Phoenix Gold 6 channel on ebay for $45 shipped, so I went with that one.
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Oct 2006
    DO NOT GET THE PHOENIX GOLD SOUND DRIVER!!!!
    i have it and its the greatest noise source of my entire system!
    i wish i could've warned you earlier.
    Aug 2007
    Utah
    Quote Originally Posted by Punky View Post
    Darn!
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
  1. Digital audio out quality help
    By speakermakers in forum General MP3Car Discussion
    Last Post: 10-06-2007, 01:05 AM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  3. poor audio quality, need help
    By llajumpvid in forum Car Audio
    Last Post: 02-06-2007, 07:48 PM
  4. Quality of Intel MacMini audio
    By SigENeaT in forum MacCar
    Last Post: 01-11-2007, 05:12 PM
  5. Bad audio quality
    By _GdR_ in forum Car Audio
    Last Post: 10-07-2004, 08:47 AM
