Results 1 to 4 of 4
Thread: BMW e46 connecting Speakers to PC HELP PLEASE
    Feb 2009
    Unhappy BMW e46 connecting Speakers to PC HELP PLEASE
    Hey,
    Im trying to go simple and im going to use a Laptop and a xenarc touchscreen in my project, I am new at this. im going to move the OEM cd player and move the climate control down and put the xenarc screen in the space. Im having difficulty on how to connect the car system to my LAPTOP, so when i play a song on my laptop i can hear through the car speakers, CAN SOMEONE PLEASE GIVE ME SOME HELP WITH THIS
    THANK YOU
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You need to check whether the OEM HU has an AUX in, then if it does you run a lead from the audio out of the Laptop to the AUX in of the HU.
    Mar 2007
    Thumbs up reply
    Quote Originally Posted by Jake17 View Post
    Hey,
    THANK YOU
    if your mounting the xenarc monitor accross the where the OEM HU was and moving the climate control down, then im assuming your getting a bezel made to fit into this space? also in order for you to get audio, your going to have to get an amplifier, (any budget, 4 channel amp will do) or what ive done on my e46 is relocate the HU (aftermarket alpine CDA 9855) into the compartment on the right (assuming your car in right hand drive) near the steering wheel, the headunit has sub controls and an aux input. Hope this helps
    [LIST][*]Car PC]
    Windows XP Pro SP2
    Centrafuse, Xenarc 700TSV 7" Touchscreen
    Asus P5K-VM Motherboard
    Intel Core 2 Quad Q6700 2.66Ghz
    4GB Geil 1000mhz PC2-8500 RAM
    320GB Hitachi SATA II HDD
    Pioneer DVD RAM Drive
    Reverse Camera[*][/LIST
    Jan 2009
    Pacific Northwest
    I've yanked the Headunit out of my '03 E46 and kept the factory amp. I bought the adapter harness (for swapping Headunits) and went from 2 line-outs of the PC to a couple of 1 channel line drivers, to a Sven4 to the factory Harness. Without the line drivers (that boosts ~1v output of the soundcard up to 4-10v, the audio was a little too quiet. Sounded OK till I got up to speed, but then full volume was not loud enough. I really wanted to avoid having the Headunit in the glovebox or trunk. If I had more cash to drop, I would replace the amp too, and may have not needed the line drivers...
  1. BMW E46 Boot PC
    By synkro in forum General Hardware Discussion
    Last Post: 02-10-2007, 12:59 PM
  2. Replies: 3
    Last Post: 02-06-2007, 06:40 PM
  3. Questions about PC Speakers
    By BonerDoner in forum Newbie
    Last Post: 06-19-2005, 09:53 PM
