Results 1 to 7 of 7
Thread: Smallest mini-ITX case?
    Constant Bitrate Pseudo Nim's Avatar
    Apr 2005
    in the snow
    Hey all,
    I'm trying to stash my car PC as far away as humanly possible. What is the smallest case people have come across so far that would only hold 1x 2.5" hard drive and 1x laptop CD? (or maybe even no CD, if that exists).
    [edit] but must be able to fit the slightly higher heatsink of the Intel Atom / GLY boards (or maybe a lower profile heatsink install...) - not going with VIA this time around.
    Thanks,
    -pN
    Doko ni datte, hito wa tsunagatte iru...
    My BMW 335xi install
    My Subaru Impreza install (now retired...)
    Realtime audio freestyle hiphop battles online - www.letsbeef.com!
    Jul 2006
    I have several of these cases I purchased for a project gone bad.
    I used one for my car pc. The specs are:
    10.5x9x2.5 inches
    Comes with a 90W PS.
    I have an Intel Atom Board - The latest
    I mounted a second fan and a hard drive with a little persistence. (mounting a 2.5" is possible but the case does not support it from factory. Also no CDROM support)
    Has 2 USB ports in the front.
    Msg me if interested.
    Elsewhere
    Would an Ampie case accomodate the taller heatsink?
    If not, have you considered replacing the tall heatsink with a lower-profile heatsink/fan unit?
    How about the Wiki?
    Apr 2005
    in the snow
    Quote Originally Posted by DarquePervert View Post
    Definitely replacing with an aftermarket fan is an option. Most likely it would have to be done, since the stock fan is highly inefficient in that it's not even copper, so there's a lot of space wasted.... I had a $25 copper fan on my previous car PC, and it did the job quite well, at half the height [I had the Little Valley GLY2 board].
    The Ampie case looks a bit large, though. I do not know how much space I'm playing with yet (need to get my dealer to get me to measure one of the devices that plug into those spaces) but it's either a CD-changer or a Sirius satradio unit that I'd be "emulating", so it would probably have to be rather small. Definitely thinking around 2" thickness max. Ruggedness is not an issue as I don't expect it to be dropped anywhere (or subjected to excess heat).
    Feb 2008
    I think the Eee Box has these kits beat
    Yeah the Eee is no super power-house of a machine and doesn't have dual video output, (maybe the B204 or B206 model does) but heck, they're cheap!
    I've just installed one on my rodeo, seriously sweet.
    MSI is also building a similar machine, if it hasn't already been released.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    I have the dual core atom in this
    morex CS 5677
    Case dimension: 58.5(H) x 258.5 (D) x 186 (W)
    no space for optical drive
    can also squeeze 1 pci card in if its small with a flexi pci riser cable
    available from the store here on mp3car
    http://store.mp3car.com/Morex_5677_M..._p/enc-022.htm
    Apr 2005
    in the snow
    Quote Originally Posted by stevey500 View Post
    You know........ I have clean forgotten about the EEE box. That's an interesting idea, in some way
  1. Hardware Review: Mobile Computing Solutions Mini-ITX case
    By Dingo509 in forum The Review Palace
    Last Post: 12-06-2007, 08:25 AM
  2. VIA PCI Riser, how do I put it on, and will it fit in my case?
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 10-02-2007, 08:39 PM
  3. FS: Mini Itx Motherboard..Ampie Case and Ram
    By EsKALad in forum Classified Archive
    Last Post: 01-24-2007, 02:45 PM
  4. *WTB* Mini ITX board with case and CPU
    By Kevin22 in forum Classified Archive
    Last Post: 02-18-2006, 10:32 PM
  5. cheapest mini itx case?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 05-14-2003, 05:28 PM
