Results 1 to 10 of 14
Thread: What hdd should I go with?
    Jul 2007
    Copenhagen, Denmark
    Here's the deal; My hdd just went belly-up, and I need a new one.
    The one I had was a 4200 rpm 40 gb.
    I didn't use Nlite or anything, just did some tweaks I found somewhere, and got the boot time from 2½ minutes to just under 2 minutes.
    I'd love to get that waaaaay down, 1 minute would be perfect...
    It's a 2 Ghz P4 with 512 gigs of memory, running XP pro and CF.
    I'm thinking of running Nlite this time, but should I choose a 7200 rpm, or ssd?
    I can live with 16 GB, no problem, perhaps 8 gb if neccesary...
    Help is much appreciated.
    (I DID search in here, but couldn't find anything helpfull, maybe I'm just blind... )
    If you can't drive a stick... You can't drive!
    Constant Bitrate RyanB95's Avatar
    Dec 2006
    Wallkill, NY
    SSD for sure. No need to worry about going over big bumps or anything. With how much the prices have dropped on them since they firs launched they are so worth it now. You can get a 30/32GB OCZ for a little over $100 or something like that. I'm using a 30GB OCZ SSD for right now until I gather the funds to get another 64GB one to use for media storage. Then I'll just use the 30GB for Windows/program installation.
    They're awesome.
    As for boot time: I think I get around 20 seconds COLD BOOT with my SSD, and probably around 10ish from hibernate. I think that alone is reason enough to grab one.
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
    FLAC WuNgUn's Avatar
    Sep 2007
    1/2TB, 7200RPM desktop drive...just make sure you mount it vertically!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by WuNgUn View Post
    We as a user community have no proof at all that drive orientation matters.
    That being said a desktop drive is a fine solution, many of us have been running them for years and in some cases 10+ with no issues.
    The cost per gig is really in the desktops favor.
    TruckinMP3
    Read the FAQ!
    Nov 2005
    Is it possible to connect a SSD drive to an Intel 201 board which only has IDE drives. All the SSD I see to buy are SATA.
    Are there adapters SATA to IDE or similar available?
    Elsewhere
    You would need a SATA controller. They make PCI models that are pretty cheap.
    However, I don't think that the added expense of an SSD is worth it. I would go for a standard-issue 2.5" IDE HDD.
    Save yourself some money and hassle.
    How about the Wiki?
    Sep 2007
    Quote Originally Posted by TruckinMP3 View Post
    It's just common sense that you'd mount it vertically, with the heads travelling perpendicular to the direction it's going to receive the most shock and G loads...
    I had an OmniFi MP3 player for the car once, which used a 40GB laptop drive, and even they recommend mounting the driver vertically for this very reason...
    If your HDD gets head-crash, that's all she wrote for that drive!
    And I surely don't need to tell you how close the heads run over the platters, do I?
    No proof? Maybe...but why chance it? Go ahead and mount your drive anyway you wish!
    Newbie vorin's Avatar
    Feb 2009
    Southern Illinois
    I'd go with a large 2.5" too, the cost per gig is worth the extra boot time.
    Dec 2006
    Wallkill, NY
    I'm not sure if this was the ONLY reason for my old hard drive failing, but I had a regular 2.5" IDE HDD held by velcro to the lid of my lock box. It was mounted horizontally and eventually failed and would no longer boot up. Not sure if that was the only reason, but I had it in my mind that the way it was mounted certainly contributed to it failing. I supposed it could have been pure coincidence as well. Either way it gave me an excuse to get an SSD .
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    You always hear about the drive failures, why would anyone say anything about a drive working normally? Just like the front page of newspapers is more often than not all doom and gloom.
    I had a 2.5" drive mounted horizontally in a car with stuff suspension for 6 years, it never missed a beat, even when I tried to cook the thing due to inadequate cooling. The drive is still working perfectly.
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. HELP - resume issue - HDD broken?
    By quinrod in forum General Hardware Discussion
    Last Post: 01-28-2007, 09:40 AM
  3. HDD gone bad?
    By VanMan69 in forum General Hardware Discussion
    Last Post: 08-07-2004, 06:55 AM
