Results 1 to 5 of 5
Thread: How to ground when powering accessories off of pc supply?
    Low Bitrate willmeyer's Avatar
    Feb 2009
    DC
    Hi there. I am planning to run one each 5V and 12V power lines from my power supply (M2-ATX) int he trunk to my dash area, one for my lilliput and one for my SB hub. When doing this, I was planning on just running the power lines then grounding to a grounding point in the dash, given that the negative for the motherboard is actually coming off the body ground as well. I read in someone's post about using a DC-DC supply and not wanting to ground it that way, though.
    Is/was my original idea the right way to do this? Any reason I need to actually run the power supply negative/ground and use that?
    Thanks!
    Jul 2006
    Brisbane, Australia
    Not sure what others have done, but I made sure that I grounded everything back to the power supply, not to the body of the car.
    I think from memory, I tried to earth to the chassis to isolate some hum but around that time I blew a fuse on the power supply.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
    Jan 2008
    Dartmouth, MA
    Yeah you need to ground back to the power supply in most cases. Most power supplies play with the power in such ways that it's almost as though the power supply and the cars electrical system are entirely independent circuits.
    Also think of it as... in a house, you wouldn't ground your hard drive back to a wall socket, would you?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Feb 2009
    DC
    thx
    Ok thanks guys. Yeah I suppose it makes sense, though I would have thought board ground was body ground etc etc. In any case, will keep the negative going from the supply to the accessories.
    Jan 2008
    Dartmouth, MA
    also, don't forget to use fuses on those lines. you don't want to blow a power supply and risk taking out other components too.
