Ok, I know myself and a couple others here have mentioned that the Realtec ALC888 chipset does not output rear
sound when you're playing standard audio...
I'm happy to report though, I found a way to force it...all by dumb luck no less.
1. In the HD Audio control panel, set it to 2Channel Speaker in the drop down list.
2. Plug in your Stereo to RCA converters one at a time. Select Line Out for all of them. MAKE SURE YOU HAVE AUTO-POPUP ENABLED!
3. Go back and Change to 6Channel Speaker in the drop down list.
4. Go back to Audio I/O screen, change 1 to Front Out, 1 to Rear Out, and 1 to (optional) Center/Sub Out.
Dont ask me why, but this works....I dont know how or why, but it does... After doing the above, I now have 4channels of sound, with independent front/rear volume control.
I will do some more
testing to see if anything will change this, but as of right now, in/out of hibernation will not revert back to only front output...
