Results 1 to 5 of 5
Thread: Controlling HD44780 LCD via USB??
    Jan 2001
    Post Controlling HD44780 LCD via USB??
    Has this been done? Where can I find info on it? I have 2 Seiko LCD's, a 4x40 and a 4x20. I will be using Linux as my OS, so that may be a problem, too. Can any of you guys help me out here? Thanks
    Aug 1999
    Yorba Linda, CA
    Post
    If you're looking for an off-the-shelf solution, your best bet is probably a USB to parallel converter module and just run the standard parallel port LCD control software. Companies like Digi ( www.digi.com ) and others sells these. I'm not sure if the parallel port adaptors work well under Linux, as I haven't tested them myself yet. Has anyone done this and had success?
    If you want to built a circuit, I believe Microchip ( www.microchip.com ) has a new PIC chip with USB capabilities built-into it. You could also try searching the web for a USB microcontroller or USB prototype board. I've seen small boards with a USB type B connector on them and the necessary IC's to convert the data to parallel format suitable for interfacing with a microcontroller.
    That's all I can think of right now. Let us know what you find out.
    -Jason
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
    Mar 2001
    Perth, Australia
    Post
    Buy a parrallel port card pci that will let you control both under linux.
    Aug 1999
    Yorba Linda, CA
    Post
    I believe he was asking specifically about _USB_. It's a good idea since the cable is smaller and power is included in it
    Jason Johnson
    http://www.m2pc.com
    Mar 2001
    Post
    So get a parallel to usb adapter, but use a short parallel cable and a long USB cable.
    I don't know of any LCDs that come with USB interfaces.. so unless you want to get a program a stamp...
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
