Well, in theory, each sub would TRY to get 100W if connected in parallel. Unfortunately, the amp cannot supply the 200W, and what happens then will depend on teh amp. Some will cut off, some will just get distorted, either way, it isn't preferred.
Each Sub has 4Ω impedance. Connecting them in series will result in an effective 2Ω impedance to the amp. Some amps are designed for this, some are not. You'll have to check the specs on the amp to see if it is designed to operate at 2Ω or not.
There are options though. You can, if you like, connect the speakers in series. this would result in 8Ω impedance to the amp, and would not overload it. Again, though, results will vary based on the amp.
Another option, since to mentioned using 4 speakers together, is a series parallel arrangement. Connecting two 2-speaker series strings together in parallel will result in a total impedance of 4Ω, which is exactly what the amp wants.
LinkBack URL
About LinkBacks
