Results 1 to 8 of 8
Thread: The wire power: 1x 0AWG vs 3x 4AWG
    Mar 2009
    I have a probleme I can not pass a 0AWG from the hood to my truck is 3 wire 4 AWG will have the same capacity of the 0AWG.
    Mar 2009
    near Rochester, NY
    What are you looking to power? No computer should need even 1 4 AWG wire, if you are installing a few thousand watts worth of amps as well then maybe you need that kind of capacity.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    unless you are really needing a massive amount of power.
    4 AWG is the most I've seen people using to power a PC and that's most likely overkill.
    Want to:
    Vendor - Qube colin's Avatar
    Dec 2006
    You can use 3x 4awg, they should work just fine.
    I almost had to do that too.
    Feb 2009
    Quote Originally Posted by FouFF View Post
    They make drills ya know. Drill a hole and do 0ga. it will be cheaper and right. I mean im assuming ur doing a large system.
    147.9 on TL @ 44hz so far.... it will do a 150
    http://i569.photobucket.com/albums/s...bmw/carsig.jpg
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Use a grommet and fuse it at the battery connection. If you short a wire that big without a fuse, you'll get a fire in the insulation and maybe in the car.
    Want to:
    Mar 2009
    I will have a 600watts inverter and for now 1 amp of 900 watts soon another of 1600watts amp. a second battery in the trunk and to a complet that a 2.4 farad capacitor.
    Feb 2009
    Name the amps being used. Amps are all rated so differently and people dont know what #s to look @. if your amps will be pushing that much power from the RMS rating there is no doubt you need to run 0ga.
    also what subs and impedance?
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 10:10 AM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  3. Replies: 7
    Last Post: 02-08-2007, 03:39 PM
  4. Power Source and Ignition wire ??
    By CoupeE46 in forum General Hardware Discussion
    Last Post: 02-05-2007, 12:42 PM
  5. Dont understand how to connect power wire to pc
    By Stillalive2029 in forum Power Supplies
    Last Post: 06-22-2006, 01:55 PM
