Results 1 to 9 of 9
Thread: Bluetooth GPRS
    Oct 2002
    Greensboro, NC
    Bluetooth GPRS
    I purchaced a USB Bluetooth dongle the other day to use with my Ericsson T68 for internet on the dash pc.....
    Im running Windows XP Pro with Service pack 1 which supposedly includes Bluetooth support.
    With the dongle attatched, the PC sees the T68 and they can pair...so I set up the DUN (Dial Up Networking) to dial *9***2# and hit connect......BAM....it connects and I can surf....so feeling like I accomplished something, I went to bed.
    Woke up this mornging and decided to try it again (the pc was running all last night and absolutly no changes were made to ANYTHING.......and it wont connect....gives me the error that "the port is already taken or the modem is not configured propperly"
    Any ideas??
    DigitalDub
    1200 mhz duron/ 384m pc133/ 6.4 gig for OS / 75 gig storage/ 32 meg Nvidia Geforce2 wit TV out / onboard sound / GPRS / 7" digitallww flip out / X10 Mouseremote / 255w inverter (temp)
    Audio
    Nakamichi CD-45Z HU / Monsoon amp and 8 speakers
    Oct 2002
    Greensboro, NC
    DigitalDub
    Audio
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Try shutting the phone off for a min. or two and power it back on and try...if you haven't done this already.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Sep 2002
    Just North of Toronto, Ontario, Canada
    just a thought along the same lines as the last post, try restarting the computer. its not something you want to do all the time, but at least you'll know one solution if you cant find any more.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Im sorry to hear your luck, but bluetooth still seems to be a bit flaky. my boss has an ipaq with bluetooth support, and has tried 3 differnt makes of bluetooth pc adapters, and only got the pocket pc to sync with the pc via it breifly with the second one, and compaq has no answers.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Oct 2001
    England
    Did you disconnect from the internet properly, or simply walk away (untill the phone was out of range)?
    If you just walked away the computer and/or phone might think they are still connected and not let you connect again.
    Incedentally, my XP has never really liked my bluetooth dongle - check some other services (ie connect to serial port of phone) to see if it is just DUN that has stopped working, or the whole bluetooth connection.
    Low Bitrate Mr. Pute's Avatar
    May 2000
    Berkley, Michigan, United States
    Superfly,
    Who's network are you on. If you are on AT&T, they've got software that's even faster than using the # sign connection method. Give their service department a call and they'll be more than happy to direct you do it.
    Status: 95%
    Phase: Final Steps
    Current Project: Tweaking
    System Stats:
    AMD Athlon XP 1700+ 256MB GeForce4 Ti4200 128MB AGP8X
    DigitalWW TM-701L In-Dash LCD w/touchscreen
    Slim DVD Tray Load 8.1GB Laptop IDE HD
    Power Inverter with Mucha Shutdown controller
    Check out my car!!
    Check out my website!!
    J-Body of Michigan (J-BOM)
    Oct 2002
    Greensboro, NC
    I actually downloaded the non us spec drivers for the usb bluetooth dongles that I am using that allow a DUN setup and it now works like a champ as I am typing this on the GPRS connected via Bluetooth to my Ericsson T68 and its pretty reliable too.
    Mr. Pute..I tried to use our Mobile Connection Software (I work for AT&T Wireless ) but it still would not connect and has only limited support for bluetooth connections..... but its up and running like a champ! this is a dry run test from the house to see how it went....gonna reinstall the comoputer in the car and see how it goes from there...i will post later with an update.
    Ill run some connection speed tests in various locals to see what i come up with..
    Thanks for all of the help gang!
    DigitalDub
    Audio
    Oct 2002
    Greensboro, NC
    Update....im now out and about and decided to check and see what kind of speed im getting....according to Bandwith Speed test im getting 30.6 kilobits per second transfer....not too bad....not the fastest but i can live with it
    DigitalDub
    Audio
