Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Automatically bypassing 'Delete restoration data...'
  1. #11
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Are you using the BT keyboard with the native dongle that was supplied by the manufacturer? In most cases, if the BT keyboard is matched with original dongle, then it should work even when windows is not loaded (it just appears as a standard USB keyboard to the system).
  2. #12
  3. #13
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by nobb View Post
    I'll try that (Logitech DiNovo Mini) next time (fingers crossed)...
  4. #14
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I've got the Dinovo Mini as well and I can confirm that if you pair it up with the OEM Logitech dongle, then you will be able to use the keyboard even before windows loads just like you would a USB keyboard.
    Although bypassing this issue is just a bandaid to the problem. I would look into why you are getting these bad resumes in the first place. The only time Ive ever had hibernation resume issues was when I had a hard drive go bad, or when the weather was too cold.
  5. #15
    Jul 2006
    Brisbane, Australia
    I think the issue occurs when a USB device which was in the system when hibernating dissappears on the resume. So ask yourself "What is dissappearing?" Touch screen? HDD, memory stick? Never remove a USB device from a hibernated system. You probably aren't, but something is making this happen. Pehpas a device driver is not being recognised. Maybe you could try using DEVCON which you can download from Microsoft to clean out and reinstall all your USB devices.
    Sapre a thought for us laptop users. If this happens, to me, I have to unbolt the rear seat and pull out the laptop becasue the message is on the laptop monitor not the external montor. Annoying.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  6. #16
    Sep 2007
    It happend again this morning...and seems to only happen in the morning, on it's first attempt to resume...so maybe it's weather related, as it's been getting down close to freezing at night here....
    I also had a thumb drive plugged in yesterday, but I'm pretty sure I removed it when the PC was running.
    About the DiNovo dongle...does it have to be paired up in Windows first, for it to work, or can it be connected at 'the prompt' and be used?
  7. #17
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by WuNgUn View Post
    I can use mine at "the prompt" it is bluetooth but works outside windows as a USB keyboard.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  8. #18
    Nov 2008
    Ahmedabad, India
    Quote Originally Posted by rodweb View Post
    Yes. same issue with me. i removed few USB devices during my new PSU installation. Any solution ?
  9. #19
    Mar 2009
    Alright, i guess i didnt understand your problem. if this is a reoccuring issue after you have reset your hyberfil.sys it is likely a driver issue. Microsoft has a knowledge base article on this particular issue http://support.microsoft.com/kb/907477.
  10. #20
    Sep 2007
    Thanks for the link...but I dunno if my situation applies exactly. I've only had this issue on the first bootup in the morning, where it freezes at 100% resume...
    After resetting the PC and passing the prompt, everything is fine...
  1. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  2. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  3. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  4. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  5. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
