Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: Automatically bypassing 'Delete restoration data...'
  1. #31
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    Anyone found any solution for this yet? I got this this morning when it was too cold outside, -20C...
  2. #32
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I have this problem one in a while. When it happen and my wireless keyboard run out of battery in the Matrix, I'm stuck with out a freaking carPC when I'm already pull out of the driveway and lazy to to inside to get new battery or a nother keyboard.
    I still have that tiny usb keyboard for PS2 in the glove box for my Supra and it come handy in this case.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #33
    Jun 2007
    Solution found
    not sure if this working on XP... SURE DOES ON WIN7
    on command Prompt type: bcdedit /set bootstatuspolicy ignoreallfailures
    BAZINGA!
  4. #34
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    That's what the "reset" button is for. Mine is easy to get to, I just pop the dash off, find something metallic and short the jumpers. If you'rs isn't so easy to get to, just wire up a momentary switch that's out of the way but you can get to it when you need it. Much easier than carrying around an extra keyboard.
  5. #35
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by txspazz View Post
    And what does that solve?
    When it starts again it still tries to come back from hibernation and fails, and then asks if you want to delete then restoration data.
  6. #36
    Feb 2008
    TEXAS
    For me it restarts and works. I've only had it happen a couple times. Maybe it has something to do with whatever caused the resume to fail to start working. Maybe it's a unique issue I have but it works for me when I have had this happen.
  7. #37
    Oct 2011
    Hi,
    we are also using Win XP Embedded and are experiencing the same problem. Is there an easy way to bypass the "delete restauration data..." menu without disabling the hibernate function?
  8. #38
    FLAC WuNgUn's Avatar
    Sep 2007
    I'm guessing, Windows 7 using Hybrid Sleep
  1. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  2. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  3. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  4. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  5. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
