Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Automatically bypassing 'Delete restoration data...'
    FLAC WuNgUn's Avatar
    Sep 2007
    I've had a bad resume a couple of times on the carputer, and after restart, I get that stupid dialog, 'Delete restoration data or continue with resume'...
    Which isn't a real big deal, EXCEPT you need a ******* keyboard to acknowledge one of the options!!!
    Twice I had to run into the house, grab a USB keyboard, plug it in, and choose an option...
    Is there a way to have Windows automatically choose one or the other after a failed attempt?
    Mar 2009
    It is likely that your hyberfil.sys (file that stores hybernation data) is screwed up. you cant just delete this file, disable hybernation, then your computer will delete this file. then reenable hybernation. this "should" fix your problem.
    Hybernation settings are located in the power options under the control pannel.
    A-Z
    A-Z is offline
    Constant Bitrate A-Z's Avatar
    Feb 2005
    Atlanta, GA
    Disabling hibernation defeats his purpose. This happens to me sometimes as well so I just keep a small usb keyboard in the car for this purpose.
    Sep 2007
    Quote Originally Posted by dblack View Post
    Thanks, but ummm, did you read my question??
    lol
    When you get the prompt I mentioned, the PC holds for user input...there is no count-down or anything...It'll sit there forever, and when you power off and restart, you get the same prompt...
    The ONLY fix is using a keyboard to select the prompt...
    Unless someone knows another way?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by WuNgUn View Post
    lol
    I never found a way around that either.
    In the end, I just purchased an RF remote and keep that plugged in for those occasions.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Sep 2007
    I have a BT keyboard, but that's no good in DOS
    Today, it wouldn't even recognize my USB keyboard up front on the hub! I had to mount it in the damn trunk directly to the board...
    Worked perfectly well before on the hub!
    Aug 2006
    Sun Diego
    Yeah, my RF remote takes up a slot directly on the board.
    Doesn't even work on a powered hub.
    Constant Bitrate lacning74's Avatar
    Apr 2008
    not an answer to your original question, but this RF usb wireless keyboard works for me connected to my 7 port non-powered hub whenever i get that annoying delete restoration data screen.
    Mar 2009
    ok, let me explain again, when your system boots up, it checks the hyberfil.sys file to determine if your computer was in hybernation or not, if this file is screwed up, your computer will see the screwed up hyberfil.sys file, then bring up the prompt. under normal circumstances, you cannot delete hyberfil.sys, because your computer will claim that it is in use. disabling hybernation causes your computer to delete this file. after the file is deleted, you can reenable hybernation, and hopefully, your problem will be gone.
    Sep 2007
    I know the in's and out's of hibernation...again, this is not what I'm asking...
    Thanks for explaining it to me twice though! lol
    Both times this occured to me, it got to 100% of resuming, and hung...on the next reboot, I get the prompt. Regardless of whether it was damaged or not, it will still resume properly ONCE I tell it to try resuming...
    BUT ALL I WANT TO BE ABLE TO DO IS REBOOT, AND RETRY THE HIBERNATION RESUME WITHOUT HAVING TO ANSWER A ******* PROMPT THAT REQUIRES A ******* KEYBOARD PLUGGED INTO THE ******* PC!!!!
    If you can't tell me how this is possible, then lets just leave it at that, shall we?
    Thank you...
  1. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  2. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  3. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  4. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  5. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
