Page 10 of 10 FirstFirst 12345678910
Results 91 to 97 of 97
Thread: Zotac + ION = Nice MB ;)
  1. #91
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Quote Originally Posted by yellow99 View Post
    Hi,
    Is there anyone who tried to connect two D-Sub VGA displays to a Zotac Ion?
    I have an A-E version and i cannot get two Analog Displays connected to the board.
    The DVI port on this board is a DVI-I Dual Link (Digital & Analog)?
    I am using this adapter:
    Same issue with the Zotac 630i. Apparently there is no analog signal on the DVI, only digital.
    I'll probably pick up an inexpensive USB-VGA adapter at some point to drive a second display.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  2. #92
    Newbie yellow99's Avatar
    Dec 2004
    The Netherlands
    Quote Originally Posted by Zogg View Post
    thanks for your reply Zogg, i am not looking for a work around but for a solution...
  3. #93
    Sep 2009
    I've read through these posts a few times now and as Im new to carputing Id like a bit of help regarding power supplies for these.
    Which is going to be the best solution -
    Zotac ION-ITX-A with its 19v DC external supply + CNX-P1900/CNX-P2140
    Or
    Zotac ION-ITX-D with a 20pin ATX connector + M3-ATX 6V-24V 125W Intelligent Car PSU
    Want to install it in an M350 Universal Mini-ITX Enclosure
    Also will need power for a dash mounted touch screen, I assume I will need a seperate PSU for this also
    Thanks for any help!
    Dan
  4. #94
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    you can use your CPU PSU to power the screen, just make sure you dont use all its power. Ex my board eats about 15W (mesured) monitor claims to eat 5W (hmmm) PSU claims to give 125W so technocally im only usning 20 out of 125 for both monitor and touchscreeen ;-)
    Automotive LED Headlight Module High Power VS HID NEW
    Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
  5. #95
    Sep 2009
    Quote Originally Posted by tempgp View Post
    Thanks for the reply, but it didn't really answer my question
    Which is going to be better/easier/cheapest?
  6. #96
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    There is no "solution" other than use a monitor with DVI or HDMI input. You cannot run a vga monitor off of the DVI out on this board. Plain and simple.
    I know it seems like it should work, it has all the right holes, etc, but I have not been able to get VGA out of it at all. I'd love to find out why though.
    http://www.cartft.com/community/carp...?topic_id=4393
    Tidder
    Try RevFE
  7. #97
    Sep 2005
    Sorry to bring an old thread back from the grave, but I'm in the same situation and need a 12V-19V DC-DC adaptor to power a Zotac ION N330 board with 19V input from a CarNetix CNX-P1290 with a 12V output. Does anyone know where I can source one of these in the UK?
    Thanks!
    Car news and wallpaper site: www.carfeed.net
  1. MSI Fuzzy 945GM1 MB dead?
    By Jistari in forum General Hardware Discussion
    Last Post: 08-20-2008, 03:40 AM
  2. WTTF Nice momentary switches/Rocker switches
    By CavityCr33p in forum Classified Archive
    Last Post: 04-14-2005, 12:44 AM
  3. Looking for a really nice small toggle.
    By kiltjim in forum General Hardware Discussion
    Last Post: 04-01-2005, 11:05 PM
  4. FS Lilliput 7" faceplate fabbed into Saturn ION dash
    By brandon in forum Classified Archive
    Last Post: 08-24-2004, 09:51 PM
  5. FS: MB Quart Seperates and Rear Deck Fills
    By Krystos in forum Classified Archive
    Last Post: 01-09-2004, 08:34 AM
