Results 11 to 20 of 27
Thread: **Please help!! disk drive/windows issue
  1. #11
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i just thought of something if you want to rule out software from hardware try using a live environment, if it fails in the live environment then it hardware if it doesn't the it's software.
    here's some instructions:
    http://www.tacktech.com/display.cfm?ttid=359
    or if you're familiar with Linux you can download a prebuilt one. (MODs it's free under GPL licence, i don't want another hit for warez)
  2. #12
    Mar 2009
    Thanks for the help everyone! I will try these suggestions and report back tomorrow. I really hope its not the motherboard. Not because I'm out of my warranty period, but because I'm a total idiot and redoing everything would make me want to jump off a bridge!
    Injector: Are you telling me to (a) create this disk on a different computer, then boot with the problem drive or (b) attempt to create the disk using the faulty drive on the working computer (my desktop which it always works with).
  3. #13
    Mar 2009
    Quote Originally Posted by almera View Post
    Corrupt USB enumeration in your registry, maybe just need to do some registry cleanup. ...
    * Device Manager - Uninstall USB Root Hubs
    * Regedit HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB
    * Clear out all corresponding keys
    Can you explain how to "clear out all corresponding keys"? There is a multitude of subfolders under that path.
    **Also, I don't know if this helps or not (think it will):
    The cd/dvd drive shows up as a folder with this path:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\E num\USBSTOR\CdRom&Ven_TEAC&Prod_DW-224SL-R&Rev_1.08
    that folder had 6 subfolders. all 6 have subfolders "device parameters" and "logconf" but the first subfolder of the above TEAC folder also has "control" too.
    Is my computer thinking the cd drive is a mass storage device? should it be?
  4. #14
    Constant Bitrate almera's Avatar
    Aug 2004
    First try this: http://support.microsoft.com/?kbid=314060
    And if it does not solve your problem then;
    Export your registry to a file, remove the subfolders in the following registry keys. If all else files you can double click on the registry file to add the items back in.
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB Printers
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\U SB Storage
  5. #15
    Mar 2005
    Rockledge, FL
    just be careful you don't remote the upper Enum folder, i did it after being fed up with bad drivers but i made a backup of the removed keys thinking i would just be able to restore them if anything went wrong, man was i wrong it removed all my drivers including mouse and keyboard which left me with literally no control of the pc, i had to boot in my Linux partition to fix the registry.
  6. #16
    Mar 2009
    ok, I tried the suggestions by both Injector and almera. Thanks for the help guys. Unfortunately, the problem is not fixed, but I believe we have made some progress.
    The dvd drive now shows up as a dvd drive. thank god!
    BUT, it won't read anything. Here is what it does:
    - after doing this and rebooting, it showed up AND read a data disk.
    - then it would not read a different disk I put in it, none after the 1st (including trying the first disk again
    - it still spins up every disk I insert for like 3-5 seconds, then stops
    - trying to browse the disk shows nothing in the drive.
    Thoughts?
  7. #17
    Oct 2006
    i hate to say it, but i have a gut feeling that its the motherboard.
  8. #18
    Newbie VYSSO3's Avatar
    Dec 2008
    Melbourne Australia
    I have the same issue and it resolved itself - I changed the cable from a 3m ti 1m USB - the longer cable would make the drive spin and seek forever with no results.
    Have you tried a shorter cable?
    Fighting for peace is like screwing for virginity...
  9. #19
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by Phoenix750 View Post
    Thoughts?
    did you try in in the live environment?
  10. #20
    Mar 2009
    Injector, in post #12 I asked for clarification on the "live environment" idea because I'm unsure of exactly what you are suggesting that I do.
    VYSSO3, the cable is only 12" long and the drive/cable work perfectly on other computers.
    Punky and all, is there any way I can test the motherboard to definitively conclude that the motherboard is bad? Since its warrantied, I'd much rather replace the mobo than reformat windows.
  1. Another Lilliput issue, Maybe
    By djmickyg in forum LCD/Display
    Last Post: 05-04-2008, 05:29 AM
  2. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 10:00 PM
  3. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 09:34 AM
  4. Video Full Screen On/Off issue - 1.1.0.9
    By Kimota in forum StreetDeck Bug Reports
    Last Post: 12-12-2007, 09:06 AM
  5. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 01:19 PM
