Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: **Please help!! disk drive/windows issue
  1. #21
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    a live enviroment is a full running os that does not run off the hard drive but instead it runs off the cd, this allows you to test your hardware with clean software without having to reinstall windows
    http://wikigiz.com/2008/02/03/create...ows-xp-live-cd
  2. #22
    Maximum Bitrate DeltaFX's Avatar
    France
    I had the same with my old USB-powered zip250 drive : wouldn't reads a disk . I gave up. 8 months later the puter started acting strange, stalls, hangs etc.... The 5V rail of my PSU was falling. This PSU died in a loud bang 2 days later. Fortunately, it was on the bench.
    Maybe your PSU is, ahem...
    Now Galileo is real. Muhahahahaha :p
  3. #23
    Mar 2009
    Injector, I will do this and report back.
    DeltaFX, the drive does the same thing with or without additional power (short usb cord) plus I tested the 5V output with a DMM at idle and under load and its constant.
  4. #24
    Mar 2009
    Ok, I got it all working. It turns out I was missing two files from my original windows installation. Once I figured out which ones I was missing, replacing them and re-"setting up a windows installation" w/"Repair" fixed it.
    I think this past month's work was caused by one scratch on my boot disk.
  5. #25
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    What files were they? I'm having a similar issue with the same drive. Thanks.
  6. #26
    Mar 2005
    Rockledge, FL
    how did you find out that was the issue?
  7. #27
    Mar 2009
    How did I find out? Dumb luck.
    One of my buddies said that in the process of streamlining a service pack into a boot disk, he had a similar issue. So, I used my same boot disk on another hard drive and the same thing happened.
    I will get back to you on which files they were late. Thanks for everyone's help!
  1. Another Lilliput issue, Maybe
    By djmickyg in forum LCD/Display
    Last Post: 05-04-2008, 06:29 AM
  2. M4-ATX Power On Issue
    By PacketSniffer in forum Power Supplies
    Last Post: 04-24-2008, 11:00 PM
  3. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 10:34 AM
  4. Video Full Screen On/Off issue - 1.1.0.9
    By Kimota in forum StreetDeck Bug Reports
    Last Post: 12-12-2007, 10:06 AM
  5. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 02:19 PM
