Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Low power AGP graphics card. Any suggestions?
    Nov 2008
    Just installed my car PC - and getting a few niggles. The carputer randomly shuts down and restarts again.
    I've deduced that it's not heat as the CPU isn't getting over 55/60 deg c.
    It doesn't appear to be anything to do with poor road surfaces and shocks. As I've been pretty brutal over some bad roads and it doesn't trigger the shut downs.
    After searching on here it's two possible things - a poor earth or something takes just too much power and tips it over the edge.
    The only pattern that's beginning to form is when I use the visualization in Centrafuse is often shuts down shortly after it's began. Which leads me to think my AGP graphics card pulls too much power on load.
    So Question 1,
    Does an Nvidia 128mb 5600XT sound like a could use too much juice and shut the PC down? I've searched but I can't see a power usage for this card. Anyone have any ball park figures?
    (I'm using the M2 ATX with an AMD Athlon 3000+ single hard drive and a screen that's taking 10w on the 12v rail)
    Question 2,
    If it sounds like the Graphics card - what's a cheap low power AGP alternative - enough to watch a DivX movie in centrafuse.
    Mucho cheers for any help
    Nov 2008
    bump... anyone?
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Michael,
    We're going to need to know more about your hardware before telling you if it's enough. What all is the M2 running?
    If you've got dedicated graphics, and a bigger processor, you might be maxing out that video card.
    This calculator will help you get a better idea of where you stand power consumption wise. It's a pretty nifty calculator that I just saw today in another thread.
    Have you tried using the integrated graphics (if you have them) to see how they run your movies?
    Nov 2008
    No I've not got integrated graphics
    I'm running:
    a Shuttle FN45G Motherboard,
    a single 512 DDR chip,
    AMD Athlon 3000+,
    a single 40GB 3.5" hard drive,
    one 80mm case fan.
    The single din motorized screen (10w on 12v)
    USB device -
    2.5" external hard drive powered via USB bus,
    wifi dongle,
    bluetooth dongle,
    OBD scanner
    Currently no other PCI cards or CD/DVD roms
    That antec site is really good! Why haven't I come across it before
    And definitely looks like I'm teetering on the edge for power... Can I underclock the graphics card? Would that help if it is possible?
    Jan 2009
    Iowa
    What I would do, for testing reasons, is remove all other variables.
    Pull as much off that power supply as possible and try to recreate the issue.
    Your best solution is going to be to upgrade the power supply - that would be the most reliable solution.
    The video card you have now, does it have a fan on it? You might look at buying a lightweight video card that has no fan.
    Maximum Bitrate DeltaFX's Avatar
    France
    Athlon 3000+ ? Are you crazy ? You are powering a CPU that typically dissipates 58.4W (and 68.3W in worst case) of heat, drawing 41.4 A (worst case) with a M2-ATX ? A M2-ATX rated to deliver 8A on the 5V rail - that is 40W - (12A for less than a minute- 60 W).
    Tss tss tss... I use an asrok k7s41gx, Geode NX1750(XP1600+ @1.26V 14W) 0.5A 2.5 HDD, a slimCD drive, and I don't fell confortable with the idea of M4ATX ...
    *mumble* Cursed Newbz ...
    Well, as Jpinkertonsaid. Upgrade your PSU...
    Now Galileo is real. Muhahahahaha :p
    Nov 2008
    Quote Originally Posted by DeltaFX View Post
    Cursed Newbz !
    stfu - your calling me a newb, FYI not all socket A mobo's power the CPU over the 5v rail. Those with a P4 connector (like the shuttle mobo's) use the 12v rail. Which the M2 actually kicks out 96 watts (120 for that short term peak)
    So no, not ideal, but I was doing the green thing and reusing all the bits that I have left over from old PC's.
    Nov 2008
    Quote Originally Posted by jpinkerton View Post
    Cheers - that sounds like a plan - I actually can't remove that much from the system - I'm down to minimum anyway. One stick of ram, the cpu, the graphics card, the windows hard drive.
    I suppose I can remove the portable USB hard drive and a few others. That should take a wee bit off.
    May 2009
    Hello everyone. I came across this thread from a Google search, and I don't mean to hijack the thread, but I've got a quick question for DeltaFX:
    I'm not into car computers, but I've got a low-power Athlon XP box that I use for web browsing and downloading. I have been looking absolutely forever for a mATX Athlon XP board that undervolts, which looks like what your board does. Can you confirm this? How low does the vcore go, and how is it controlled? Do you manually set the value or is it some kind of percentage under/overclock?
    Sorry if I'm derailing the thread a bit, but I have been looking forever for this. Thanks for answering!
    Jan 2009
    Iowa
    I'd pull all the USB parts you can and see if it makes a difference.
    Does your graphics card have a fan? If so that's extra power, I know there are kits out there to convert a graphics card to fanless, but it might be more cost effective to buy a new fanless one.
    Another thing you could try is hooking it all up inside on the bench using a desktop PSU that is a bit more beefy. See if you can replicate the issue then, you won't be testing the PSU so much as just the wattage.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. where can I find low profile sound card?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-04-2006, 02:05 PM
  3. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  4. Power setup scenario - Suggestions?
    By Coeus in forum Power Supplies
    Last Post: 01-16-2005, 04:30 PM
  5. PCI Graphics or Sound card - EPIA M10000
    By ZimZimmer in forum Newbie
    Last Post: 08-05-2004, 11:02 PM
