Results 1 to 5 of 5
Thread: What do you think of this sbc?
    g60
    g60 is offline
    Jul 2000
    van,BC
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2513772890
    Only thing is what kind of lcds use a 50pin connector?
    >\\MP3G60//<
    Apr 2002
    North Yorkshire, UK
    Dont quote me, but I believe that you will need to supply it with power over the ISA / PCI bus.
    Also, the VIA EPIA will be about the same size area wise, but more managable as it is sqaure.
    Dave
    g60
    g60 is offline
    Jul 2000
    van,BC
    specs and manual here.
    http://www.tri-m.com/products/aaeon/sbc675.html
    Seems it supports a celeron up to 466mhz, and can be powered by a AT ps.
    For $15, it seems like a good deal to screw around with.
    >\\MP3G60//<
    Aug 2002
    midwest
    I believe you will need a backplane to plug this board in to. It could be prohibitively large once assembled.
    Coodaddy
    Feb 2002
    Ontario, Canada
    you only need the backplane if you plan on adding any other cards to the system. The SBC has the power connectors right on the board.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
