+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: USB socket in dash solutions? show me yours!
    Nov 2007
    after putting a connects2 device to my golf, i want to run a USB socket either on the dash or in the ashtray.
    i searched and found this:
    http://www.l-com.com/item.aspx?id=7299
    which looks alright for the astray but i wouldn't want it mounted on the dashboard.
    what have people done in the past? is it a simple case of getting a hole cut to the right size and glueing it behind the panel? surely theres something better out there?
    Feb 2008
    Indash isn't that hard really. It just consists of cutting the right sized hole somewhere that you can get the hardware behind.
    What I did was take the front connector package off a standard computer. This included 2 audio connections and 2 USB connections. In addition, I stole the wiring that connected it all. I then just hooked inline 1/8" stereo jacks onto the audio connector wire, and a USB cable end onto the end of the usb. After epoxying the little board in place, using a little filler and paint, it ended up looking like this:
    Dec 2007
    Reading, PA
    The round bubble (because I know some people will ask!) is my re-located IR sensor for the touch screen, so I could retain use of the remote control, if need be.
    "Commercial links are not allowed in signatures. Please read the forum rules" - says the Enforcer
    Nov 2007
    how did you mount the socket to the back? something like this would be prone to breaking off right?
    Feb 2008
    I was lucky enough to have the little tray there really with my install. The board fit down flush against it, then I just mixed up some epoxy and poured it all around it. There's about a 1/4" of epoxy in the piece to hold it in.
    That said, its probably overkill. You want a good strong glue to hold it in. Elmer's won't cut it. I would suggest the epoxy route though. You don't have to go overboard, just get a strong connection.
    Dec 2007
    Reading, PA
    Quote Originally Posted by seventynine View Post
    I roughed up the back of the plastic, and used 2-part epoxy. Trust me, it's not going anywhere!
    Nov 2007
    it would have been nice to have a one stop solution, something that looked factory out of the box. i don't mind digging out the fiberglass and texture paint but it never looks like it should have been there in the first place
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Nov 2007
    that would be perfect, but i still occasionally use the cigarette lighter for things like satnav n stuff. plus the location of mine would mean that i couldn't close the ashtray with an MP3 stick in it. and that was ideally what i wanted.
    i'm a fussy swine really
    FLAC WuNgUn's Avatar
    Sep 2007
+ Reply to Thread
  1. USB Jack mounted into dash?
    By 20mg in forum General Hardware Discussion
    Last Post: 01-08-2008, 07:04 PM
  2. USB recognition issues
    By Brycestro in forum Software & Software Development
    Last Post: 10-25-2007, 11:35 PM
  3. USB Adapter for XM Direct
    By timekiller in forum Linux
    Last Post: 10-16-2007, 12:21 AM
  4. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  5. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
