Results 1 to 3 of 3
Thread: Pre 1995 OBD 2 interfacing...
    Low Bitrate lbergamo's Avatar
    May 2009
    Michigan, USA
    Hello,
    I have scored the web and have really found nothing when it comes to interfacing a PC with OBD 1. I have completed my car PC project and now would like to add somethings like this to my setup. The vehicle in question is a 1994 Dodge Ram Van B250. I have located the OBD plug it is in the engine compartment under the cowl. Any help would be sincerly appreciated.
    Thank You
    Leo
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    the problem is that obd 1.1 really does not exists, before the standard obd II every car manufacturer used their own protocol.
    i would suggest taking a look in the obd sub section maybe you can find something
    http://www.mp3car.com/vbulletin/engi...agnostics-etc/
    Low Bitrate nalav's Avatar
    Apr 2009
    Louisiana
    OBD I generally didn't offer much other than a few trouble codes. You won't be able to get the fancy gauges and stuff this way. Though, with a bit of ingenuity, you could potentially tap into the wire for your existing gauges (assuming they all have electric senders) and monitor those with the computer.
  1. OBD II connector on an OBD I car
    By HearseNurse in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-23-2009, 10:52 AM
  2. OBD or special hardware?
    By Jirka Jirout in forum General Hardware Discussion
    Last Post: 03-04-2007, 06:01 AM
  3. OBD in 1995 Chevy G20 van.
    By VanMan69 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-20-2005, 02:15 PM
