Results 1 to 10 of 10
Thread: Zotac 9300 ITX board bends with CPU cooler
    Nov 2008
    I just bought a Zotac 9300 board with a 3.16 GHZ dual core chip and when i installed the cpu cooler the board bends a bit, I have never seen a board do this before and was wondering if it was supposed to be doing this. I just dont want it to break down the road.
    Low Bitrate eigenVector's Avatar
    Apr 2009
    I've got the zotac 8200, and installed an Arctic Cooling Low profile heatsink and it seemed like it was gonna bend a little too. (Keep in mind, this is an am2+ board)
    AM2+ chips have to have a backplate, and the hs came with its own that seemed similar to the one that came with the motherboard, but it was more flexible. This backplate bent for sure when I screwed the heatsink on. I think this kept me from actually bending the motherboard.
    So if intel socket chips use backplates, make sure you use the one that came with your cpu cooler if it did.
    Nov 2008
    mine looks just like this one it bends a lot haha
    Apr 2009
    Yea, that would make me nervous. If you loosen up the screws a bit will it straighten up and still seem to have a good contact?
    Jun 2008
    Seattle, WA
    I don't remember, but do mini-itx boards screw down at 4 points, or 6? If it's six points, then it might straighten out when you install it in a case. If it's just the four corners, then obviously it won't.
    Nov 2008
    its got push pins you just push into the board it doesnt have screws.
    Apr 2009
    Quote Originally Posted by kross View Post
    It's got 4
    What heatsink is that?
    Nov 2008
    stock intel cooler
    Apr 2009
    Quote Originally Posted by bmw_car_pc View Post
    stock intel cooler
    **Before doing this, see if this is what others do**
    Is it standard practice to install the heat sink after installing the motherboard into the case? Perhaps having the motherboard already stable (screwed into your case) will help the push pins set in their correct position without applying too much force.
    Jun 2008
    Seattle, WA
    I only have one socket LGA775 board, and when I installed the cooler, I did it on the pink foam that it came with, to provide some back support while pushing the connectors through. If these boards only have standoffs at the corners, then pushing down while it is "suspended" between them will only cause more flex, not less.
    I don't know why LGA775 sockets don't have backplates, like AMD socket AM2/AM2+/AM3 does. But regardless, the motherboard makers know the cooler causes the board to flex, and they don't seem to care, so I guess it's okay for the boards.
    -- Kevin
  1. Celeron mobile cpu on a standard s478 board
    By GuiltyLionel in forum General Hardware Discussion
    Last Post: 09-27-2005, 04:05 PM
  2. ITX board recommendation
    By ptk in forum General Hardware Discussion
    Last Post: 10-03-2004, 01:24 PM
  3. best mini itx board
    By 2nau-t in forum General Hardware Discussion
    Last Post: 09-08-2004, 11:05 PM
  4. MINI ITX board
    By llmask in forum General Hardware Discussion
    Last Post: 07-29-2004, 11:26 AM
  5. wtb: cheap epia itx board
    By e36mp3 in forum Classified Archive
    Last Post: 09-18-2003, 02:25 AM
