Results 1 to 5 of 5
Thread: Analogue inputs into CarPC - eg Batt Volts?
    May 2009
    Hi Guys,
    How do I get analogue data into the CarPC setup? I'm planning out the system now so not yet decided on the hardware but I am unlikely to put in an OBDII link since I am not really interested in most of this data.
    I am, however, interested in battery voltage for the primary and secondary batteries and would prefer these to appear on the screen instead of on dedicated instruments.
    For an industrial setup I would do this through a PLC or RTU but this seems completely overkill just to get some basic levels into a PC.
    Is there a simple ADC with serial output option I could use? How do you guys do it, especially for systems with a second battery that isn't visible through the OBDII link?
    Apr 2009
    Aussie
    fusion brain or phidgets can easyly do this plus more...
    May 2009
    We build custom boards based on the Rabbit Semiconductor SmartStar system. It's WAY overkill for this.
    http://www.laurels.com/transmitters-4-20.htm
    Modbus interface gets you a couple analogs.
    A few more:
    http://www.superlogics.com/serial-da...ystems/115.htm
    http://www.omega.com/toc_asp/subsect...n=D01&book=DAS
    http://www.iotech.com/?mc=5GGL
    May 2009
    Thanks for that - those Phidgets are *exactly* what I have been looking for but for some reason the old google results weren't coming up with the goods...
    Cheers
    Jun 2009
  1. An interesting solution to adding phone support to CarPC
    By AvWuff in forum Hardware Development
    Last Post: 02-08-2009, 12:35 AM
  2. Head Units with RCA inputs
    By bitwaba in forum Car Audio
    Last Post: 06-04-2008, 02:30 AM
  3. INPUTS - 12V Volts <> 5 Volts
    By vultan in forum Fusion Brain
    Last Post: 01-31-2008, 11:29 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
