Results 1 to 9 of 9
Thread: Aopen i45GMt-HD & miniPCI-E SSDs
    ptk
    ptk is offline
    Singapore
    Wonder if anyone this board and get it to work with mini PCI-E SSDs similar to those found in netbook ?
    Was thinking it will be sweet to pair the board with a MDD's 64GB SSD.
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    Elsewhere
    SSDs aren't PCI-E. They are either IDE (also known as PATA) or SATA, just like a mechanical HDD.
    I don't see any IDE connectors listed int he specs for the board, so you'd need a SATA model.
    How about the Wiki?
    Mar 2006
    Blog Entries
    1
    SSD now come in PCI-E format.
    ptk
    ptk is offline
    Singapore
    Quote Originally Posted by BlackStealth View Post
    yup. that's right bro....
    ptk
    ptk is offline
    Singapore
    Hi guys
    it's alright. i figured it out. dugged out their installation guide. It seems that the board's mini PCI-E slot have SATA lines in it, effectively allowing it to take mini-PCI-E SSDs.
    Mar 2009
    near Rochester, NY
    If you were thinking of something like these, remember that they are pretty slow, so if you want it for speed you would be far better off with a decent 2.5" SSD
    ptk
    ptk is offline
    Singapore
    Quote Originally Posted by strikeback03 View Post
    some thing a bit faster. the runcores (like these http://www.mydigitaldiscount.com/Cat...ini+PCI-e+SSDs )
    going with SSD isn't really for the speed but for shock resistance. my car's a little bumpy...
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    They do come in PCI-E format, I think thats what all the net books use.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    ptk
    ptk is offline
    Singapore
    Dear All.
    to clarify the matter. a quick answer is no. while the connector is a mini PCI-E edge connector, the pin outs are totally different. in fact, on eeePCs, they are labelled as flash_con (flash connector) instead of PCI-E.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
