aluminum is good for heat and its easy to work with.
Im making a case to fit the components in the layout that I can fit. but I have a question. what material should I use to make the case? weight is the major concern... I was thinking like 1/4" plexiglass, but I was told metal was a better choice since it will ground the computer...
is there a way to ground it with wires to the metal frame rather than a metal case? if metal is the only/better way what kind of metal should I use? sheet metal obviously, but steel, aluminum, something else? try to reccomend something I can get at home depot...
I've seen a few plexiglass cases that are running with no problems. I wouldnt worry about it
dont need to take care to ground it in some form or fashion? people said it would build up a charge...
ground??
I dont think thats necessary.
I know they used to make these little wires that you can attach to some part of the motherboard to the case.
But honesly I've never used one and have had no problems.
Mine needs to be updated.
Traditional metal cases do act as a ground plane.
If you are very worried about it use a metal mainboard tray from a metal case and put that inside the plexi case....
Many plexi cases are running just fine without it. I have heard stories of plexi cases not containing all the electronic "noise" and messing with TV reception or garage dorr openers ( I am not sure I belive them)
Metal case = Faraday cage
Plexi case <> Faraday cage
Faraday info
TruckinMP3
Read the FAQ!
On my old system (made of wood) there was loads of radio interferance when the PC was on. Since my new sysetm is being jammed into an old CDROM case which is made of metal, Im hoping this will no longer be a problem.
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
If you are worried about grounding all of the components in a plexi case you can just wire all of the components togther with wire and connect it to the ground on you car chasis.
