I'm having the same interrogations as you are. After a lot of researches, I found that part that matches exactly the connector on the VoomPC 2.
However, I have a couple more questions before ordering:
Will I have to buy separate terminals and wire and solder it myself? Is there a place where I can buy complete connectors with terminals and a couple of inches of wire so I can just solder the wires I need on my cables?
Also, is there any counter-indication about leaving a wire to the battery unplugged? I want to be able to plug/unplug my carputer easily so I can take it out for extensive updates or during winter. I was planning to wire it directly to the battery as explained here and finish the wire with a molex-connector. Can there be any problem of leaving the cable hooked but with nothing plugged at the end?
LinkBack URL
About LinkBacks
