Results 1 to 8 of 8
Thread: Cable Layout questions.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have started the install of the six additional computers and the rewiring of the main PC. I decided to run all the cables in the upper frame work of the car, I had to run VGA extension and USB extension. All this combined created way to much wire to run in the floor. I want to figure out what can be run along those cables. I have the audio and power buttons which I will run through the upper part also, but will it cause EMI? I was also going to run the speaker wire, but since so much of the cabling is being run up, it will down. I do have the cars original wiring and some extra wiring for the rear pc control, but should I worry, or would it be better to run the speaker wire from the top also? Need input please!
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Mar 2007
    Barbados
    You can run the VGA, USB and audio signal and power buttons together as they are low current wires and the EMI will be negligible. Whether you run the speaker wires and power wires together depends on how much power you are using. It is possible to induce spike in the speaker wire if they are too close to the power wire during high or prolonged transients.
    Jul 2007
    Miami
    Quote Originally Posted by wired48 View Post
    Now its going to maybe be the other way around, the Audio will be high powered. I think now that I have deleted the old speaker wire and I'm replacing it with high grade wire, I should be fine running it on the floor. Everything else I will run from the top. Is it true that if you have good quality amps, EMI is also almost non existent?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    FLAC WuNgUn's Avatar
    Sep 2007
    Did you say 6 additional computers?? Sheesh!
    Good quality amps go a ways towards low EMI...but they won't eliminate it. They could possibly even amplify it! Good quality components thruout, as well as good grounds (including the 'Big Three') help as well...
    I have zero noise in my setup, and I didn't do anything special with it...
    Jul 2007
    Miami
    Quote Originally Posted by WuNgUn View Post
    Yes 6, I am trying to go for the most massive install possible, lol. The 6 will not be connected through the main amps though, they only work with headphones.
    What I tried to do wiring wise is eliminate long runs. Like before, I had it so that the audio cables from the SB Xtremegamer needed extensions to reach the back. Now that I have rerun the cable through the middle, all those extensions are gone. It now connects direct to the AMPS. There is stuff crossing the cable though, 6 USB cables, and a DVI cable. Other then that I will also have two M4-ATX PSUs, which power the six PC units, the ethernet switch, and the access point. I went ahead and took the wires for the camera system power, relay wire to turn on the M4s, Amp wire and video for camera, and weaved it into the current original wire. That wire doesn't run 100% along the base of the floor, and in the floor near the seats it runs in the track. I intend to run the audio parallel with it with about a 2 inch gap. I am thinking with high grade wire that it will shield anything that may bother it. If I do have EMI, it shouldn't be much so I will use the GLIs, but I really don't want too.
    PS: What is the big 3?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Jul 2007
    Miami
    Also, what type of speaker wire do you recommend.... Alpine recommends 12 gauge wire..... but is there any other thing about the wire I should be looking for?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Jan 2008
    the big three is power, ground and alternator wires. he is saying that upgrading all three of these wires could help later on.
    for mids and tweeters, 16-12 ga is fine, subs should have at least 12 ga or larger.
    I don't like to run any less than 14 guage audio wire--I have used 14ga home theather wire, in the white jacket. currently, I am using pro series 13 ga 4 conductor to my mids/ tweets, and 12 ga monster cable sub wire.
    14/2 wire: http://www.parts-express.com/pe/show...number=100-762
    'pro series' 13/4(overall size is near 1/0 ga):
    http://www.parts-express.com/pe/show...number=100-485
    automotive speaker wire is a waste of money-- the rockford fosgate 12 guage 'sub' automotive wire from best buy, is equivelant to most 18 guage wire that i have used in the past, but with a thicker insulator. in a pinch, I would use this for tweeters.
    Sep 2007
    12AWG is pretty big...but probably neccassary for high power and/or long runs...
    It can't hurt.
  1. vga cable for lilliput
    By JaxPt in forum LCD/Display
    Last Post: 02-24-2005, 11:52 PM
  2. Replies: 2
    Last Post: 02-04-2005, 11:15 AM
  3. Usb Cable Questions
    By (6) in forum LCD/Display
    Last Post: 02-02-2005, 06:12 AM
  4. 1:1 Hirose Cable Group Buy!
    By claylong in forum Classified Archive
    Last Post: 08-31-2002, 03:55 PM
  5. Replies: 3
    Last Post: 02-08-2002, 12:25 AM
