Results 1 to 6 of 6
Thread: PCI slots not being recognized...
    May 2008
    Was hoping you guys could shed some light on this issue. I have an ECS Goal3+ GS7610 ULTRA (V1.1C) mobo. Shown here. I recently reinstalled WinXP SP2 on a fresh, brand new HD. I updated the BIOS to the most current and everything went smoothly, until Windows booted and my SparkLAN MIMO WPIR-300 Wireless PCI card and Soundblaster Live! 5.1 PCI Audio card weren't recognized as new hardware by Windows. I tried loading drivers to them manually but Windows doesn't even see that they've been installed so that's a no go. I've tried resetting the CMOS on the mobo and got into the BIOS to overclock the CPU and such but theres nothing really pertaining to resetting the PCI slots... I've tried booting the PC without the cards physically installed and then making sure nothing shows up in the Device Manager for the slots, then shutting down, physically installing the cards again, and still no go. Any thoughts? I need my sound and internet!!! I'm pretty sure it's a BIOS issue but not sure what or where to change a setting.
    Variable Bitrate csfile's Avatar
    Feb 2009
    you should be able to enable/disable pci in your bios. Is it possible that when you updated your bios, it was disabled as default?
    Elsewhere
    ECS = (In my opinion)
    First of all, PCI in the car can be problematic, as the cards can come dislodged from bumps and vibration from driving. IF you're using a case with a means of locking PCI cards in place, then you're better off. If you're not using a case, I'd look for USB solutions instead of PCI in order to prevent cards wiggling loose while driving.
    Second, I sincerely hope you haven't installed in the car yet. If you're at this stage, you really should be testing everything on a bench at home (or work or the laboratory or wherever).
    How about the Wiki?
    Jan 2008
    Dartmouth, MA
    Have you installed the "official" chip set drivers from the vendor website?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    May 2008
    csfile: Yes, it is very well possible that when I updated the BIOS it disabled the PCI slots, but I can't find anywhere in the settings how to enable them...
    DP: Yes, I am bench testing before installing it in my car. I'm using a good case and will figure out a way to secure the PCI card. When this system goes into my ride it will only have the sound card and not the Wireless LAN card. I'll be using a USB solution for wireless at that time.
    PaulF: Yes, I downloaded the "official" drivers straight from ECS's website.
    I'll go get into the BIOS again and toggle whatever mentions PCI and see what happens.
    May 2008
    Changed some BIOS settings and they're working now. I just didn't want to mess up my BIOS too much. Thanks.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Need Mini PCI slots?
    By Giuliano in forum General Hardware Discussion
    Last Post: 12-06-2006, 02:52 PM
  3. More pci slots?
    By sporty_drew in forum General Hardware Discussion
    Last Post: 05-16-2006, 08:42 PM
  4. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 10:59 AM
  5. adding pci slots?
    By etrik in forum General Hardware Discussion
    Last Post: 04-04-2001, 08:28 PM
