Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Is there a fast booting ATOM 330 board?
  1. #11
    Mar 2009
    near Rochester, NY
    I know I looked into one of the MSI Fuzzy boards, it gave power specs which seemed to be acceptable. Finding that detailed of info is unfortunately difficult.
  2. #12
    Elsewhere
    Power specs for a motherboard are pretty similar across the board. CPU, video chipset and onboard devices make the lions share of the power draw.
    Look at those to determine power draw of your system.
    How about the Wiki?
  3. #13
    Mar 2009
    near Rochester, NY
    The problem is when power is allocated in weird ways. The LF2 with its excessive 5V draw being an obvious example. I don't know if anyone has measured the draw of the individual rails on an Ion board to see if it also draws a lot of 5V, or if it is more of the standard 12V.
  4. #14
    Oct 2006
    fast bootup
    I know it's not ION, but the Zotac 9300 boots off of an SSD in 8 seconds - from pressing the power button to a Windows XP SP3 desktop. The BIOS is blazing fast. I'm guessing the Zotac Ion motherboard would be slower due to processor speed, but maybe it's still pretty fast if it has a similar BIOS?
  5. #15
    Jan 2009
    Atom 330 boot times....
    Cold boot up = why worry??
    Resume from S3 (not hibernation) = 2-3 seconds
    Current draw in S3 sleep with a USB slot load DVD drive (powered by a power harness from the M2), a space navigator, a 7 port USB hub (with external power), USB BT dongle etc etc = less than 50mA. At that rate you could let the car sit for weeks without worrying (disclaimer: I have a BMW 740, which has a fairly substantial battery). And the M2 will shut down the CarPC completely if the battery voltage falls too low.
    I end up "rebooting/cold booting" my CarPC, maybe once a month or so.
  6. #16
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by llllskywalker View Post
    8 sec? wow! is it real boot, or simple sleep / hibernation? if its real boot, then is it a base SP3 windows, or lightened version?
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  7. #17
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    My DG45FC is so slow booting.
    25.8 sec until the beep. (including about 5sec it takes from M4 to start the thing), so to be fair is like 20 secs.
    15.2 Win7 resume from hibernation.
    total: 41s.
    Cold boot:
    5 sec. M4
    20.7 BIOS
    32s. Win7 32
    total: 57.7s. from IGN on. Not good, thanks to this Intel Bios.
    Fully loaded with all USB ports, GPS, bluetooth, Camera, JoyCon, etc.
    So yeah, I'd love to try a good and fast Atom board for my other car.
  8. #18
    Oct 2006
    This is the board i'm currently using. Bios is quite quick compared to the intel bios.
    http://www.newegg.com/Product/Produc...82E16856119012
    resume from hibernation quite fast, but wasn't fast enough for me. Currently using it with s3 hybrid sleep.
  1. Intel D945GCLF2 Dual-Core Atom
    By txspazz in forum General Hardware Discussion
    Last Post: 08-15-2010, 02:06 PM
  2. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  3. Intel Atom mini-ITX board for sale
    By Phatsacks in forum General Hardware Discussion
    Last Post: 05-30-2008, 06:34 PM
  4. New Ibase 3.5 inch Atom based board
    By _dopehead_ in forum General Hardware Discussion
    Last Post: 05-04-2008, 01:30 AM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
