20 seconds is too long?
Someone is impatient.
I spend twice that putting on my seat belt, adjusting my seatingposition and making sure I have everything I need for my journey...
OK ... I'm interested in the time in takes from supplying power till the Windows loading bar is displayed - cold boot or hibernation - not standby please
My D945GCLF2 takes 12 seconds before Windows even gets a sniff ... then a further 8 seconds to loads Windows ... so 20 seconds in total.
If I can find a board whose BIOS completes quickly I'll be a happy chappy!
DP ... lol ... you're right - the whole fast boot time thing has become a must have for me - just trying to make it as consumer as possible really!
EDIT: Just re-timed things ... currently running off a power brick - will install M3-ATX when someones got one!
Cold boot into Windows:
12secs (BIOS) + 14secs (Windows) = 26secs total
Resume from Hibernation:
12secs (BIOS) + 9secs (Centrafuse with music playing) = 21secs total
I wouldn't recommend the M3 - the LF2 just does not get along with it. Your times sound similar to mine in use though - when I was configuring the system and didn't have any USB stuff plugged in the BIOS was only a few seconds. Not sure if it is possible to get that time with the system in usable configuration though.
Add in the delay between turning the ignition and the computer actually starting though, and I am often rolling before the computer has resumed from hibernation.
Hi Strikeback03 ... I've read a few conflicting things about the M3, thing is I've gone for a M350 enclosure (http://www.mini-box.com/M350-univers...-itx-enclosure) coz space is tight & the M3 is the only thing I can find that'll fit ... got any recommendations? New mainboard perhaps???
yeah there is:
zotac aton 330, forgot the model.
asrock ion 330 ( very good board, but a bit expensive)
Anyone tried LF2 + M3 ... does it work?
I actually did use an M3 with my LF2, it worked right for about a week, went in and out for a few more weeks, then stopped responding altogether. The only USB accessories plugged in were the touchscreen and the connection to my (separately powered) USB hub.
Maybe you could fit an M2 in that front area where they show the USB WiFi dongle in those pictures?
Do you already have the M350? If so just grab (or print off) a mm ruler and measure out the area to see if an M2 would fit.
I considered the M3, but decided against it after reading some more reviews on it.
I've got a M2 mounted in a 4th Gen mocoso - I don't think it'll fit in an M350 ... I need the front USB ports anyways!
I'm assuming it's the M3's 5v 6A limit the LF2 doesn't like - and seeing as I can't find another PSU that'll fit the M350 it looks like I'll stick with the M3 and get a new mainboard with a lower 5v requirement, any suggestions?
