Results 1 to 4 of 4
Thread: 555 Timer for clicking a relay?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have been trying to figure something out for my Color Digital Quad Processor for months. Basically when power is applied it defaults to a 4 Camera mode. The car will have 4 cameras, but I will rarely use the front facing cam. There for I want the DQP to switch to the 3 way mode, which is right, left and rear. The only way to do this is to press a button every time. I would like to automate this process. Basically when the car turns on, or power is applied, a timer simulates a less then one second pulse and then turns off. I have tried googling but cant seem to find a buy-able solution. All I see are on things to build the timer (which I cant do, ive tried) nothing as a complete unit. Maybe there is something else I can buy to do what I need? Any help would be helpful.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Vendor - Qube colin's Avatar
    Dec 2006
    Search for "one shot timer". Thats the type of circuit you're looking for. You could probably do the same thing with a simple capacitor but the timer circuit is less prone to the interference in the power line from your car!
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    A resistor/capacitor + transistor should work fine depending on how the button sense circuit is set up. If accuracy is a problem you could run it off the internal power. Sort of like the old liliput auto-on hack. It may also need a delay after it turns on though.
    Jul 2007
    Miami
    I decided not to worry about switching the DQP to 3 way mode because of this. http://www.youtube.com/watch?v=XLWZU3uKLlE That is Lacning and his front view cam. Seeing this has made me reconsider and simply display all 4 cameras, which it does by default.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Automatic 555 timer, delay off
    By locked in forum Hardware Development
    Last Post: 08-04-2009, 08:18 PM
  2. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  3. AMP 1.X Phidget Plugin Interface
    By bcohen5055 in forum AMP
    Last Post: 09-06-2007, 01:10 AM
  4. Replies: 19
    Last Post: 07-27-2006, 04:44 AM
  5. using a 555 timer to suspend
    By wizardPC in forum General Hardware Discussion
    Last Post: 12-27-2000, 01:58 AM
