Results 1 to 10 of 10
Thread: Voom Case 2nd HDD
    Variable Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    Voom Case 2nd HDD
    Afternoon,
    I've read that the Voom PC enclosure (Ampie) will accommodate two HDDs. I'm considering using a 2nd HDD or SSD and wondered whether anyone has any pics of two HDDs fitted?
    I received some fitting rails with the Voom PC enclosure but couldn't see the information in the instructions......
    Many thanks,
    Dave
    Vauxhall Astra SXi Car PC installed.
    Mar 2005
    Norfolk UK
    Curious for pics, anyone done this?
    Thanks,
    Dave
    Mar 2005
    Norfolk UK
    This is also known as a MoSoCo case aswell. Anyone with pics???
    Dave
    Mar 2005
    Norfolk UK
    Bumpity Bump!
    Dave
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Also interested to know since I am looking to do this in the future when I add an SSD as a boot drive. It should be similar to my MoCoSo case. I believe there is a simple metal bracket that just puts one hard drive on top of the other, with a bit of spacing in between. Ive seen another user with this setup, but dont see where you buy it.
    You might also be able to just fabricate it yourself with two larger rectangular sheets of metal (one for each side). Or just use 4 thinner metal strips, one for each mounting hole in the hdd. Here is a quick mspaint of my idea. The dots in red are where the holes would be to secure the two hdd to the bottom plate of the case.
    Mar 2005
    Norfolk UK
    Cheers nobb,
    I've got the fitting rails but didn't know where to use them. I didn't think about on top of the first HDD, although that seems the most obviuos now you mentioned it. I'm surprised it's not in the manual at all.
    I'll post the pic if I track it down or when I do mine!
    Cheers,
    Dave
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Awesome, looking forward to the pics, it would be helpful. Unfortunately, my MoCoSo case did not come with any sort of railings, so I am going to have to improvise something for my hdd mount.
    Mar 2005
    Norfolk UK
    Food for thought and possibly the thread you mentioned here.
    Dave
    Mar 2005
    Norfolk UK
    First of all, apologies.....The MoSoCo case is similar but by no means the same. I still can't find any pics of the VoomPC (Ampie) case as yet. The search conitinues.........
    Dave
    Mar 2005
    Norfolk UK
    Just found this on the Mini-box Knowledgebase, if anyone else is interested..
    Question
    I would like to know if it is possible to fit two 2.5" laptop hard drives and a VIA EPIA MII-12000 using the M2 DC/DC power converter and the ATX extender board (all of which you sell) entirely inside the enclosure.
    Solution
    You have a set of brackets for the 2nd laptop HDD, that is mounted on top of the extusion (inside) in between the two ribs.
    Dave
  1. Physically wiring a screen from a Voom case
    By djjon in forum General Hardware Discussion
    Last Post: 04-25-2009, 03:12 PM
  2. M2-ATX and Epia CN13000 in a Voom case...No power
    By polo6979 in forum General Hardware Discussion
    Last Post: 11-27-2008, 05:02 PM
  3. WTB: m1atx and ampie case and laptop hdd
    By EsKALad in forum Classified Archive
    Last Post: 11-19-2005, 10:41 AM
  4. FS: Brand New Voom Case $65
    By dexy in forum Classified Archive
    Last Post: 10-29-2005, 03:51 PM
  5. FS:60 laptop slim hdd w/ external usb 2.0 case
    By e36mp3 in forum Classified Archive
    Last Post: 11-16-2004, 04:05 PM
