Results 1 to 5 of 5
Thread: Volume Control
    Mar 2002
    Germany
    Volume Control
    Hi, i am searching for an external volume control, because i am going to connect my Carputer direclty to my amplifier..I have no headunit so i have to control my volume external without pc. Do you know any circuit to make it by myself?
    Thank you, Beetle
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Jan 2003
    Ma
    theres also that usb knob from apple that has been floating around on the board. Its a neat idea but kind of pricy for the benefit. Personally ill be going with the rout DDT gave the link to.
    -Dustin
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I"ve just installed the david navone volume controls.. I replaced the knobs with something more appealing, but it works great... but it's just a pot inside. I'd reccomend doing it yourself.
    Mar 2002
    Germany
    The problem is, that i have already build it by my self, but i maybe can use the poti for 2 degrees or so and the max volume is reached. I canīt really use it, becaus one turn and the poti jump from volume min to volume max..maybe i have the wrong poti. Iīve used 100K poti and i have to connect it with the computer and the amplifier...
