Results 1 to 10 of 18
Thread: SpaceNavigator + RBC9 driver + Windows 7 issues
    Jan 2009
    Hi guys,
    I'm in the middle of my carpc project, and while I have most things going correctly, this one has me baffled. I'm using the D945GCLF2 Atom board (which is working perfectly btw), and I have Windows 7 RTM build (7600) installed. I have the Spacenavigator PE edition connected to it.
    Now, when I use the SN with the stock drivers (which of course doesn't help me as such, since I need the functionality of the RBC9 drivers), the SN works great, on a cold boot, resume after S3 sleep, and resume after hibernation. When I use the RBC9 drivers, and I have them installed correctly as such, since everything works (and works GREAT), the SN works fine on a cold boot, but the system does not detect the SN after a resume from S3 or hibernation.
    I have tried it on EVERY USB port in the system (including internal and external) as such, although the issue is not the USB ports, since the stock driver works perfectly as such.
    Has anybody else faced the same issues with the RBC9 drivers? Is it because of Windows 7 and compatibility? Is RBC9 still working on his drivers? (which I doubt, since I haven't seen any updated drivers. I guess 3DConnexion got to him...) Any ideas?
    On a related note, while configuring the RBC9 drivers for my usage, it has a few issues when it needs to send a key combination, like Ctrl-Shift-S for e.g. Is the right way to do that, is to have 3 individual binds? One for Ctrl and Shift key hold, one for S key press, and then one for Ctrl and Shift release?
    Please help, since this is the last stumbling block in project!
    Appreciate any input.
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    most likely i need to wai for new moded drivers as my best guess would be that mod was done for old dtivers. First time I staryed playin w/ SP (SN as u called it) it was on XP so respectively all mods i ever build where on ex too.
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
    Jan 2009
    SOLVED. You MUST use the "v2" drivers. If your driver doesn't say v2 at the end, you have an older driver. Works perfectly in Windows 7 32 bit. Haven't tested with 64 bit (and don't need to, for the carPC).
    Low Bitrate aziodale's Avatar
    Jun 2009
    Italy Sicily Palermo
    Quote Originally Posted by kapone View Post
    where to found v2 drivers?
    Jan 2009
    Jun 2009
    many thanks
    I try to replace exe file for update driver but windows 7 return an error;
    I found RBC9-SpaceNav.sys file in directory; i have to update the sys file aslo?
    how to?
    Jan 2009
    Quote Originally Posted by aziodale View Post
    many thanks
    how to?
    Uninstall the USB device (the HID device) from Device Manager.
    When Windows says "You are about to uninstall...." and provides a checkbox that says "delete driver as well..", check the box, and uninstall the device.
    Unplug the SN.
    Extract install files from the driver package that you downloaded from the site above, somewhere on your computer
    Plug in the SN again - Let Windows install the default drivers.
    Go to device manager and right click the new HID device and select "update drivers". Point it to the location where you extracted the files.
    Once done, reboot.
    You're done.
    Jun 2009
    Thumbs up
    Unplug the SN.
    Once done, reboot.
    You're done.
    Yesssssssssssssssssssssssssssss
    thanks
    Jun 2009
    Lightbulb
    I found in the RBC9 archive over drivers aslo sources;
    are public?
    may i modify interface for 800x480 resolution?
    Jan 2009
    are public?
    If the source is out there....it's for you to play with.
  1. Lilliput screen on Ubuntu
    By yam125 in forum Linux
    Last Post: 06-13-2011, 11:19 AM
  2. Full XP on USB,someone tryed this?
    By gradecak in forum Software & Software Development
    Last Post: 03-20-2008, 07:36 AM
  3. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  4. RadioXtreme Windows XP Driver
    By msreyes in forum Software & Software Development
    Last Post: 09-26-2006, 09:19 PM
  5. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 06:09 PM
