Exactly what he said. Here's what I'll be doing with mine:It's a digital I/O board. You could control an automated HVAC system with it, put your windows up and down via remote, have it control lighting or special effects, monitor voltage, monitor sensors or temperature, the possibilities are near endless.
Beside my screen I want a rotary encoder that is backlit and 5 backlit buttons. I bought a clear frame for the encoder and 5 clear light pipe buttons. The high-power PWM output will dim the blue LEDs at night and make them bright during the day. The normal I/O/A will be connected to the buttons and also to the LEDs so that they can be switched by ANOTHER PWM that will cause them to visibly blink if something exciting happens, such as a new notification.
Under that, there will be an IR detector so that I can use my Lilliput remote (with the number keys) to control my radio station and my songs. Even the punks in the back seat can have a go at it.
You can also use it when the computer messes up or when it's not even on. If you have it preconfigured, you can press a button to latch your outputs -- useful for HVAC when you have to hold something down, or window defrosts where a simple momentary switch would not work.
The analog inputs will be set to read the temperatures of the front cabin area, the back cabin area, and the outside. Based on these temperatures, the HVAC will automatically adjust to a set temperature.
Because of the serial interface, I can control two of these boards with only one USB slot.
Theres about a thousand things I forgot to mention.
LinkBack URL
About LinkBacks
