Results 1 to 10 of 14
Thread: Best USB Cables?
    Constant Bitrate NoTec's Avatar
    Jan 2009
    South Florida
    Best USB Cables?
    Pretty generic question I understand - I'm just looking for the most reliable USB extension cable that you guys have had experience with. I would prefer a 10ft USB cable - for running my OBD to the machine in the trunk and for having a USB port close to my center console for quick access.
    I have tried 3 different brands and nothing seems to either last or be reliable. Any help is appreciated. Thanks guys.
    Elsewhere
    The best one I have ever used was GE branded, shielded along the length and had gold-plated connectors.
    honestly, though, I think it was complete overkill, as I've had just as good luck with el-cheepo USB cables, as well.
    How about the Wiki?
    Constant Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    i just bought 2 12 feet cheapo's from a local store for 5 bucks each...cant go wrong.....works like a charm...no worries...so far....
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Mar 2006
    Colorado, but Canadian!
    10ft is well within USB guidelines. I am guessing you have lots of interference, try and run your data and power separately.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2009
    near Rochester, NY
    I initially bought a whole system from another guy with the same type of car, and the touchscreen didn't work reliably over a 10ft extension when sitting on the floor in my bedroom. might have just been a bad extension, or some USB devices might work better than others with them.
    Maximum Bitrate DeltaFX's Avatar
    France
    "TrendnetTu2-ex5" amplified extension -5m 15ft works fine
    Now Galileo is real. Muhahahahaha :p
    Jan 2008
    Quote Originally Posted by DeltaFX View Post
    from what i have read, all the active usb cables are hit or miss, some of the cheap ones work better than the name brand ones, and some just don't work at all.
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    I have had super good luck with the USB extension cables that Dragonext.com sells(they have an eBay store too ) They are the best and cheapest I have found that are decently shielded and work(for me, at least. )
    Project λ^2 (Lambda Squared or Lambda II)
    [☺☺☺☺☺☺☺☺] Install 80%
    Saving $ for PSU
    Coming soon: freeflashstuff.net
    It will be my business site, and it will also have a section dedicated to my previous and current builds.
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    monoprice has prices you cannot beat and their cables are of high quality. in northern california, overnight shipping is the cheapest option too at $4.73
    May 2006
    Calgary, Alberta
    I bought the cheapest ones I could find from Wal-Mart and daisy chained them. They work fine.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. FS: XM Direct + Mp3Car USB Adapter + all cables
    By RedGTiVR6 in forum Classifieds
    Last Post: 06-13-2009, 09:14 AM
  2. MB to case USB cables?
    By Profozone in forum General Hardware Discussion
    Last Post: 06-27-2007, 10:20 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. Before I lay cables, here is my USB device layout. Advice?
    By Bailey in forum General Hardware Discussion
    Last Post: 03-13-2005, 10:03 AM
  5. USB hearder cables
    By yonu in forum General Hardware Discussion
    Last Post: 03-05-2005, 03:45 AM
