Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: 12v USB Hub - $29.99 :-)
  1. #11
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by summer69guy View Post
    could i conect this on the outpout of my power suply wich goes to my xenarc screen?
    if i can, i need to conect it to the positif and do another ground?
    or can and juste conect it to the two wires of the screen?
    which device are you referring to specifically when you say "this"? Which power supply are you using?
  2. #12
    May 2006
    Calgary, Alberta
    TigerDirect is garbage. I tried to buy a $280 camcorder from them 2 weeks ago and they wanted me to fax them identification.....WTF? I asked why and he said, "We require it for all orders above $500." Okay.......math fail. I canceled that and another $250 order I was going to make, they're braindead.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #13
    Jan 2009
    soorry i am talking about tigerdirect usb hub
  4. #14
    Jan 2008
    Quote Originally Posted by Maheriano View Post
    i have not had any problems with tiger direct, and have gotten all sorts of stuff from them, granted though, there is a outlet store near me, so i just go there, so i can't speak to much on the online side of things.
  5. #15
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    How can each of the 7 ports be guaranteed 500ma with only a 2A power supply?
  6. #16
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by hailrazer View Post
    The same way a 12v amplifier can be rated at 400W, with only one 25A fuse. Marketing!
    RevFE
    My Shop
  7. #17
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by malcom2073 View Post
    But 25A times 12v equals 400 watts right ?
  8. #18
    Jun 2004
    Westminster, MD
    12 x 25 == 300
    RevFE
    My Shop
  9. #19
    Jan 2008
    Dartmouth, MA
    Because the power supply is 2 amps at 12 volts and each port is 500ma at 5 volts.
    12 volts x 2 amps = 24 watts;
    24 watts / 7 ports = 3.43 watts per port
    3.43 watts / 5 volts = .686 amps
    .686 amps = 686 mA
    I'm sure whatever electronics that are in the hub use some power for themselves and efficiency is never 100% so the actually number is probably closer to 500 mA than to 686 mA, but it definitely is possible that each port gets 500 mA.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  10. #20
    Jan 2008
    Dartmouth, MA
    Oh and also... heres my 2 cents on the hub...
    If it is taking in 12 volts and outputting 5 volts, it has some sort of regulator inside of it. I bet that regulator accepts a range of volts and not just exactly 12 volts. The only way to know is to test it with a multimeter though.
  1. disable power to a usb hub?
    By dragons0088 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-05-2009, 07:00 PM
  2. D945GCLF2 + USB Hub
    By Urbanmindz in forum General Hardware Discussion
    Last Post: 05-20-2009, 10:37 AM
  3. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 04:42 PM
  4. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 09:16 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 02:06 AM
