Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: 12v USB Hub - $29.99 :-)
  1. #31
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Don't use the Lilliputs power regulator (hence forth known as the egg) because they are carp.
    Use a proper regulator.
  2. #32
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by Enforcer View Post
    Mmmm carp. Tasty.
    I second that though, use the output from your PSU if you can.
    RevFE
    My Shop
  3. #33
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    As already mentioned I can't use the regulated output from my Carnetix, not enough amps.
  4. #34
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    i havee this hub and it is excelnt.
    since i am using a power inverter to power up my lappy, powering the hub was a pieve of cake, plug and play.
    ir works perfectly with hibernation, i have not yet had a device that i had to replug or didnt work after hibernation.
    i really recomment this hub ... keep in mind it BIG !
    even by taking it apart, you cant really make it smaller to fit to tight spaces. i have a truck and still had hard time finding a room for it.
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
  5. #35
    Jun 2004
    Westminster, MD
    You won't need that much unless you're actually planning on using that much, but it wouldn't hurt to buy a higher output regulator.
    RevFE
    My Shop
  6. #36
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by malcom2073 View Post
    All 7 hubs are needed, whether or not they'll use that much who knows.
    But the point is there's no way the P1900 will power it let alone it and my Liliput.
  7. #37
    May 2007
    I don't understand. What's so special about this USB hub?
    I picked up one of these on sale for like 8 dollars. Wired to +12 on my M2-ATX. Have 5 devices running off of it without any problems - Wifi, Bluetooth dongle, USB webcam, GPS, I-BUS adapter and occasionally a USB flash drive. Why so excited about the 29.99 price for this one?
  8. #38
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by PaulF View Post
    Oh and also... heres my 2 cents on the hub...
    If it is taking in 12 volts and outputting 5 volts, it has some sort of regulator inside of it. I bet that regulator accepts a range of volts and not just exactly 12 volts. The only way to know is to test it with a multimeter though.
    I agree. There is definitely a 5V regulator that can handle at least 3500mA with some degree of input tolerance. At least +/-1V minimum, and I'd expect the wall adapter to be at least 14V no-load. There could also be some parts using the 12V but I doubt it. Someone could always post up pics of the PCB and we could figure it out.
  9. #39
    Oct 2009
    Starting slow
    I am a certified newb, so please excuse the simplicity of my question and interest at this point. I am still researching a path on a carpc, but I would like to get a hub installed to power phone, Zune and etc sooner vs. later. That would allow me to poke around under the hood (literally) and get a better understanding of my options for wiring and placemet. It would also potentially limit the damage I could do to my car and wallet if I find I'm solder challenged.
    Sorry for the long intro, but it seems that most discussion around USB hubs assume you have a base PC or regulated power source to plug into. Considering I do not, would you recommend a hub like this perhaps with 2 x 7812 Regulators and a capacitor balancing the input and preventing spikes to the hub? Or am I missing the mark completely?
    Thanks in advance
    FYI - My car is a 2006 BMW X3.
  10. #40
    Mar 2004
    Florence Yall, BFKY
    I think you're missing the mark. You don't need a hub for powering/charging. The normal lighter socket USB/zune/phone/etc. charger will do the trick for less.
  1. disable power to a usb hub?
    By dragons0088 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-05-2009, 06:00 PM
  2. D945GCLF2 + USB Hub
    By Urbanmindz in forum General Hardware Discussion
    Last Post: 05-20-2009, 09:37 AM
  3. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 03:42 PM
  4. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 08:16 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 01:06 AM
