Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: 12v USB Hub - $29.99 :-)
    Jan 2009
    Tigerdirect has the Ultra ULT33056 7 port USB Hub for $29.98 and it takes 12v DC in (yes, 12v, not 5v). With Goggle checkout you can even get $5 off, if you add a filler item for $1.
    USB Hub on Tigerdirect
    ptk
    ptk is offline
    Singapore
    would be good for someone who bought it to check if the 5V out on the usb ports are stabilised, as this probably wasn't designed for fluctuating voltage.
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Can almost garuntee it requires regulated 12v. Try to hook that up to car power and watch it go boom.
    RevFE
    My Shop
    Dec 2008
    Input: DV 12V 2A
    99% sure as well it doesnt have voltage regulation. not much different then a 5v setup in that case to be honest..
    Jan 2009
    Yeah, I guess you guys are right, I just got a little excited seeing a 12v one at a good price. I did order one, so we'll see if I fry it or not.
    Oct 2006
    either way, its still a good deal in my opinion.
    You get a massive 7 usb port and all u have to do is connect it to ur psu's 12V and you're good to go.
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by Punky View Post
    i agree with punky - or you can get MP3CAR's Power Controller Card which costs $25 bucks for use with your monitor and use your existing USB hub.
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    Quick method for regulating 12+ to 12v steady. There's a voltage drop off of around 1v or so. Using a 7505 or 7509, you can get regulated 5v or 9v too respectively.
    Note: Less then 1 amp load. You cannot get regulated 3amps by just using 3 7512s or the like, so don't try.
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    If you want unregulated 12-24v in, you could buy our p5usb. (currently 50$ with rebate)
    If you want to use the above product on a budget, you could solder into the 12v rail coming of the atx power supply to use the above hub.
    Jan 2009
    could i conect this on the outpout of my power suply wich goes to my xenarc screen?
    if i can, i need to conect it to the positif and do another ground?
    or can and juste conect it to the two wires of the screen?
  1. disable power to a usb hub?
    By dragons0088 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-05-2009, 06:00 PM
  2. D945GCLF2 + USB Hub
    By Urbanmindz in forum General Hardware Discussion
    Last Post: 05-20-2009, 09:37 AM
  3. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 03:42 PM
  4. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 08:16 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 01:06 AM
