Results 1 to 5 of 5
Thread: mounted case then a case of alternator whine
    Low Bitrate titanicmusic14's Avatar
    Jan 2008
    Pennsylvania
    How is it that I didnt have any alternator whine before while everything was testing everything with the voom pc case sitting on the rug of the trunk but now that its mounted in the trunk I have nasty alternator whine. is it because of the cases being bolted to the trunk and the case is becoming a second grounding point?
    "You know what I mean? But at the end of the day, it is what it is." - The most articulate thing someone could say.
    Aug 2009
    Birmingham - UK
    stands a good chance. it happened when i had my amp on my floor, it would slide to the side of the boot. - its now screwed to the sub box... n problem solved...
    have you tried bolting a piece of wood to the trunk and then the case to the wood? - no no metal on metal touch
    ps...
    or anyother idea get some little rubber grommets / washers either side of the case / bolt... [so the bolt doesnt actually touch the case, just the rubber...]
    Jan 2008
    Pennsylvania
    thx man.
    Quote Originally Posted by wayneox View Post
    ps...
    Aug 2009
    Birmingham - UK
    no worries...
    im not too gr8 with the hardware stuff myself [better then some, but i think most guys on here r better then me (leaving me somewhere around the lowest 3-4%)... so nice to help when i can :P
    Constant Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    seems like you are creating a ground loop. Unscrew your pc from the car and mount a piece of wood ply and then mount the pc on that with screws that wont reach to the metal...
    my car pc setup and amp is not touching the car frame ...no noise.....i do get noise from the a/c blower fan when its on cause I have to move the power wire for the pc from near it..
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  1. How to cut need holes in metal?
    By Arathranar in forum Fabrication
    Last Post: 01-08-2008, 01:19 AM
  2. Replies: 0
    Last Post: 12-26-2007, 10:52 PM
  3. VoomPC Case Alternative?
    By buurin in forum General MP3Car Discussion
    Last Post: 09-12-2007, 04:43 PM
  4. Custom mount for my OPUS 150W in ATX case
    By Sham-Mobile in forum Power Supplies
    Last Post: 10-10-2005, 11:00 PM
  5. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
