Results 1 to 9 of 9
Thread: serial port relay help - new problem
    Aug 2009
    i'm getting 11.88v from my serial port DTR pin... how can i switch a relay using this? layman's terms please my knowledge of electronics is fairly limited. i've searched the web and the info i find is either over my head or doesn't pertain to my particular application.
    Aug 2009
    anyone?
    Sep 2005
    Auckland, NZ
    I used a Pac-TR4 which can sense low voltages and give a steady 12 volt output @ 2 amps which was more than sufficient to run my amps. These are not very expensive on ebay and mines been working for almost a year with no issues.
    So the output (DTR) from my serial port is an input to the Pac TR4. Once the DTR is raised I can use TR4's output which is 12 volts.
    Aug 2009
    who'd a thunk it'd be that simple!
    thank you!!!! just what i was looking for.
    Aug 2009
    when windows is booting, serial port DTR is raised several times causing my relay to go crazy... switch on and off on and off. I'm assuming it's windows initializing the serial port.
    What can i do??? grrrrrrrrr
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    brianhj: You can put in a timer on another relay, which disconnects the line for 30 seconds (or however long) until your computer boots... otherwise there isnt much way around that issue. Search the forums, there has been discussion about this before.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Aug 2009
    that would completely defeat the purpose of having the serial port relay in the first place. did you even read the thread?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Open Regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\SerMouse, and change the value "Start" from 3 to 4.
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    How long are the pulses? I'd imagine some sort of a debounce circuit would possibly work. Perhaps something like this would do the job? If the pulses are longer, you might need to use a bigger cap? Someone with more electronics knowledge might be able to tell you if this will work for sure, and what value you'd need for the cap. I'm sure there's several other ways to make that work anyway. Perhaps just adding a single cap in line? /shrug
    Good luck,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
  1. HVAC Control on Car PC through Serial Port.
    By Mastero in forum User Innovations
    Last Post: 03-01-2011, 04:10 PM
  2. Serial Port issues, Please HELP.
    By HiJackZX1 in forum General MP3Car Discussion
    Last Post: 10-14-2008, 05:25 PM
  3. bluetooth serial port
    By tundra2000 in forum Wireless Communications
    Last Post: 04-07-2007, 01:32 PM
  4. Serial port, relay, and a bunch of LEDs
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 02-28-2007, 03:36 AM
  5. need a extra serial or parallel port?
    By Sway in forum Input Devices
    Last Post: 01-08-2004, 07:48 AM
